> 3sgte engine in car. now wont start!
post Dec 9, 2006 - 11:03 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
I started my swap last night! Got the engine out and the 3sgte mounted onto the 5s-fe trans. within about 4 hours. The motor mount next to the timing cover had to be modified to fit correctly. Ive heard before its a direct fit for the 5s-fe motor mounts. Its not! Only one bolt lines up without modifications. I took the mount to the grinding wheel and managed to make it fit well. If anybody wants pics give me your e-mail and Ill send you some pics of the mount. Hope this will better prepare some of the future swappers! later-
This post has been edited by toyotacrazy: Dec 9, 2006 - 11:06 AM
- toyotacrazy   3sgte engine in car. now wont start!   Dec 9, 2006 - 11:03 AM
- - hitcachi   actually its pretty common knowledge that the pass...   Dec 9, 2006 - 12:27 PM
- - lagos   take off your motor mount bracket from your 5sfe, ...   Dec 9, 2006 - 12:48 PM
- - toyotacrazy   Its a 95 gt celica body and a 1991 celica alltrac ...   Dec 9, 2006 - 6:28 PM
|- - celicaST   QUOTE(toyotacrazy @ Dec 9, 2006 - 4...   Dec 9, 2006 - 6:35 PM
- - toyotacrazy   I got the swap all put together. It wont start...   Dec 10, 2006 - 3:20 PM
|- - jcbass7   QUOTE(toyotacrazy @ Dec 10, 2006 - 3...   Dec 11, 2006 - 10:34 AM
|- - toyotacrazy   QUOTE(jcbass7 @ Dec 11, 2006 - 10:34...   Dec 11, 2006 - 11:27 AM
- - lagos   who did your harness?   Dec 11, 2006 - 1:23 AM
- - toyotacrazy   I did the harness. There 12 volts going to the fu...   Dec 11, 2006 - 6:17 AM
- - jcbass7   are you getting a code for your engine coolant tem...   Dec 11, 2006 - 12:02 PM
- - toyotacrazy   nope, just the code 12 = ne or g signal from distr...   Dec 11, 2006 - 12:12 PM
- - hitcachi   who did your wiring?   Dec 11, 2006 - 12:53 PM
- - defgeph   I merged all your topics. Please keep all you ques...   Dec 11, 2006 - 1:00 PM
- - toyotacrazy   I got the ewd from the tis (toyota/information/sys...   Dec 11, 2006 - 1:08 PM
- - lagos   the coil and igniter get their power from a thick ...   Dec 11, 2006 - 2:09 PM
- - Dr_Tweak   How did you do the wiring and which ECU are you us...   Dec 11, 2006 - 2:45 PM
- - toyotacrazy   Im using a gen. 2 ecu from a 91 celica all trac jd...   Dec 11, 2006 - 9:23 PM
- - trdproven   I don't mean to just throw in a question here ...   Dec 11, 2006 - 9:51 PM
- - Silver94CelicaOwner   He is using the 5SFE's S54 transmission. Not ...   Dec 12, 2006 - 12:53 AM
- - lagos   yeah, its all tied into the fuse box. this was his...   Dec 12, 2006 - 1:28 AM
- - toyotacrazy   Im still waiting for the button to arrive. I chec...   Dec 12, 2006 - 10:34 PM
- - toyotacrazy   Ok guys, If anyone has any suggestions I would re...   Dec 25, 2006 - 11:23 PM
- - lagos   QUOTEIm wondering if the coil wires black/orange w...   Dec 26, 2006 - 2:33 AM
- - toyotacrazy   I got 12v at the black/orange wire on the coil wit...   Dec 26, 2006 - 5:49 PM
- - Dr_Tweak   Sorry I didn't get back to you on this sooner....   Dec 27, 2006 - 8:50 AM
|- - toyotacrazy   QUOTE(Dr_Tweak @ Dec 27, 2006 - 8:50...   Dec 27, 2006 - 7:22 PM
- - Dr_Tweak   Okay well that's your problem right there, tha...   Dec 27, 2006 - 7:42 PM
- - toyotacrazy   omg. I hope your right. Ill look into it and get...   Dec 27, 2006 - 8:24 PM
- - toyotacrazy   Ok, I think I got this figured out. Here it goes...   Dec 27, 2006 - 9:15 PM
- - Dr_Tweak   Yeap, that's exactly right. I've had the s...   Dec 27, 2006 - 9:32 PM
- - toyotacrazy   Thats awsome. I cant believe the same thing happe...   Dec 27, 2006 - 9:58 PM
- - Dr_Tweak   It seems that every swap I do, I run into some new...   Dec 27, 2006 - 10:24 PM
|- - phattyduck   QUOTE(Dr_Tweak @ Dec 27, 2006 - 7:24...   Dec 28, 2006 - 1:50 PM
- - toyotacrazy   It runs!!!!!!!!...   Dec 30, 2006 - 12:41 PM
- - Kadett   Congrats   Dec 30, 2006 - 12:50 PM
- - Dr_Tweak   Excellent, I'm glad that we figured out your p...   Dec 30, 2006 - 4:18 PM
- - toyotacrazy   Ill get the pic on later. I posted another page w...   Dec 30, 2006 - 4:29 PM
- - Dr_Tweak   Yeah it will do that if you pinch the line off. Yo...   Dec 30, 2006 - 7:20 PM
- - toyotacrazy   Yea thats correct. I have a vacuum tube from the ...   Dec 30, 2006 - 9:39 PM
- - Dr_Tweak   Any codes from the ECU? -Doc   Dec 30, 2006 - 10:06 PM
- - toyotacrazy   The only code I have is 34 which is because I hit ...   Dec 30, 2006 - 10:20 PM
- - Dr_Tweak   Where do you have the other vacuum line from the V...   Dec 30, 2006 - 10:22 PM
- - toyotacrazy   Its all stock setup. I really didnt mess with it....   Dec 30, 2006 - 10:24 PM
- - toyotacrazy   The vacuum hose goes from the turbo, to the vsv, t...   Dec 30, 2006 - 10:36 PM
- - lagos   QUOTEThe vacuum hose goes from the turbo, to the v...   Dec 30, 2006 - 10:56 PM
- - toyotacrazy   Yea, your right. Sorry its been a long day. It ...   Dec 30, 2006 - 11:02 PM
- - Dr_Tweak   Yeah, put the MBC between the turbo and the wasteg...   Dec 30, 2006 - 11:07 PM
- - lagos   what kind of exhaust do you have on the car? if i...   Dec 30, 2006 - 11:10 PM
- - toyotacrazy   http://i140.photobucket.com/albums/r29/toy...30Ima...   Dec 30, 2006 - 11:11 PM
- - toyotacrazy   Its a stock exhaust setup. With a convertor below...   Dec 30, 2006 - 11:16 PM
- - lagos   the top vac line normally goes to your charcole ca...   Dec 30, 2006 - 11:19 PM
- - lagos   i have a crap load of swap pics, if you want to re...   Dec 30, 2006 - 11:22 PM
- - toyotacrazy   Yea I capped the small vac hose on the top. I als...   Dec 30, 2006 - 11:25 PM
- - toyotacrazy   Ok heres my best guess to why my car wont boost pa...   Dec 31, 2006 - 12:42 AM
- - CelicaGT04   QUOTE(toyotacrazy @ Dec 30, 2006 - 12...   Dec 31, 2006 - 5:35 AM
- - Dr_Tweak   The ECU isn't in safe mode. If it was you...   Dec 31, 2006 - 8:09 AM
- - toyotacrazy   Thank you for all the help. Yea...Ill just get a ...   Dec 31, 2006 - 9:37 AM
Lo-Fi Version Time is now: August 2nd, 2026 - 4:26 PM
