Dec 9, 2006 - 11:03 AM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
I started my swap last night! Got the engine out and the 3sgte mounted onto the 5s-fe trans. within about 4 hours. The motor mount next to the timing cover had to be modified to fit correctly. Ive heard before its a direct fit for the 5s-fe motor mounts. Its not! Only one bolt lines up without modifications. I took the mount to the grinding wheel and managed to make it fit well. If anybody wants pics give me your e-mail and Ill send you some pics of the mount. Hope this will better prepare some of the future swappers! later-
-toyotacrazy This post has been edited by toyotacrazy: Dec 9, 2006 - 11:06 AM |
toyotacrazy 3sgte engine in car. now wont start! Dec 9, 2006 - 11:03 AM
hitcachi actually its pretty common knowledge that the pass... Dec 9, 2006 - 12:27 PM
lagos take off your motor mount bracket from your 5sfe, ... Dec 9, 2006 - 12:48 PM
toyotacrazy Its a 95 gt celica body and a 1991 celica alltrac ... Dec 9, 2006 - 6:28 PM
celicaST QUOTE(toyotacrazy @ Dec 9, 2006 - 4... Dec 9, 2006 - 6:35 PM
toyotacrazy I got the swap all put together. It wont start... Dec 10, 2006 - 3:20 PM
jcbass7 QUOTE(toyotacrazy @ Dec 10, 2006 - 3... Dec 11, 2006 - 10:34 AM
toyotacrazy QUOTE(jcbass7 @ Dec 11, 2006 - 10:34... Dec 11, 2006 - 11:27 AM
lagos who did your harness? Dec 11, 2006 - 1:23 AM
toyotacrazy I did the harness. There 12 volts going to the fu... Dec 11, 2006 - 6:17 AM
jcbass7 are you getting a code for your engine coolant tem... Dec 11, 2006 - 12:02 PM
toyotacrazy nope, just the code 12 = ne or g signal from distr... Dec 11, 2006 - 12:12 PM
hitcachi who did your wiring? Dec 11, 2006 - 12:53 PM
defgeph I merged all your topics.
Please keep all you ques... Dec 11, 2006 - 1:00 PM
toyotacrazy I got the ewd from the tis (toyota/information/sys... Dec 11, 2006 - 1:08 PM
lagos the coil and igniter get their power from a thick ... Dec 11, 2006 - 2:09 PM
Dr_Tweak How did you do the wiring and which ECU are you us... Dec 11, 2006 - 2:45 PM
toyotacrazy Im using a gen. 2 ecu from a 91 celica all trac jd... Dec 11, 2006 - 9:23 PM
trdproven I don't mean to just throw in a question here ... Dec 11, 2006 - 9:51 PM
Silver94CelicaOwner He is using the 5SFE's S54 transmission. Not ... Dec 12, 2006 - 12:53 AM
lagos yeah, its all tied into the fuse box. this was his... Dec 12, 2006 - 1:28 AM
toyotacrazy Im still waiting for the button to arrive. I chec... Dec 12, 2006 - 10:34 PM
toyotacrazy Ok guys, If anyone has any suggestions I would re... Dec 25, 2006 - 11:23 PM
lagos QUOTEIm wondering if the coil wires black/orange w... Dec 26, 2006 - 2:33 AM
toyotacrazy I got 12v at the black/orange wire on the coil wit... Dec 26, 2006 - 5:49 PM
Dr_Tweak Sorry I didn't get back to you on this sooner.... Dec 27, 2006 - 8:50 AM
toyotacrazy QUOTE(Dr_Tweak @ Dec 27, 2006 - 8:50... Dec 27, 2006 - 7:22 PM
Dr_Tweak Okay well that's your problem right there, tha... Dec 27, 2006 - 7:42 PM
toyotacrazy omg. I hope your right. Ill look into it and get... Dec 27, 2006 - 8:24 PM
toyotacrazy Ok, I think I got this figured out. Here it goes... Dec 27, 2006 - 9:15 PM
Dr_Tweak Yeap, that's exactly right. I've had the s... Dec 27, 2006 - 9:32 PM
toyotacrazy Thats awsome. I cant believe the same thing happe... Dec 27, 2006 - 9:58 PM
Dr_Tweak It seems that every swap I do, I run into some new... Dec 27, 2006 - 10:24 PM
phattyduck QUOTE(Dr_Tweak @ Dec 27, 2006 - 7:24... Dec 28, 2006 - 1:50 PM
toyotacrazy It runs!!!!!!!!... Dec 30, 2006 - 12:41 PM
Kadett Congrats Dec 30, 2006 - 12:50 PM
Dr_Tweak Excellent, I'm glad that we figured out your p... Dec 30, 2006 - 4:18 PM
toyotacrazy Ill get the pic on later. I posted another page w... Dec 30, 2006 - 4:29 PM
Dr_Tweak Yeah it will do that if you pinch the line off. Yo... Dec 30, 2006 - 7:20 PM
toyotacrazy Yea thats correct. I have a vacuum tube from the ... Dec 30, 2006 - 9:39 PM
Dr_Tweak Any codes from the ECU?
-Doc Dec 30, 2006 - 10:06 PM
toyotacrazy The only code I have is 34 which is because I hit ... Dec 30, 2006 - 10:20 PM
Dr_Tweak Where do you have the other vacuum line from the V... Dec 30, 2006 - 10:22 PM
toyotacrazy Its all stock setup. I really didnt mess with it.... Dec 30, 2006 - 10:24 PM
toyotacrazy The vacuum hose goes from the turbo, to the vsv, t... Dec 30, 2006 - 10:36 PM
lagos QUOTEThe vacuum hose goes from the turbo, to the v... Dec 30, 2006 - 10:56 PM
toyotacrazy Yea, your right. Sorry its been a long day. It ... Dec 30, 2006 - 11:02 PM
Dr_Tweak Yeah, put the MBC between the turbo and the wasteg... Dec 30, 2006 - 11:07 PM
lagos what kind of exhaust do you have on the car? if i... Dec 30, 2006 - 11:10 PM
toyotacrazy http://i140.photobucket.com/albums/r29/toy...30Ima... Dec 30, 2006 - 11:11 PM
toyotacrazy Its a stock exhaust setup. With a convertor below... Dec 30, 2006 - 11:16 PM
lagos the top vac line normally goes to your charcole ca... Dec 30, 2006 - 11:19 PM
lagos i have a crap load of swap pics, if you want to re... Dec 30, 2006 - 11:22 PM
toyotacrazy Yea I capped the small vac hose on the top. I als... Dec 30, 2006 - 11:25 PM
toyotacrazy Ok heres my best guess to why my car wont boost pa... Dec 31, 2006 - 12:42 AM
CelicaGT04 QUOTE(toyotacrazy @ Dec 30, 2006 - 12... Dec 31, 2006 - 5:35 AM
Dr_Tweak The ECU isn't in safe mode. If it was you... Dec 31, 2006 - 8:09 AM
toyotacrazy Thank you for all the help. Yea...Ill just get a ... Dec 31, 2006 - 9:37 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 4th, 2026 - 3:35 PM |
