Dec 10, 2006 - 10:24 PM
Enthusiast Joined Jul 23, '06 From MASS Currently Offline Reputation: 0 (0%) |
i shorted out my power locks
i have the 94 st with the manual locks that move together when you push one down. i was inside the door when i realized a couple of the wires coming out of the actuator were bare and touched together. i heard something click, like a blown fuse, and the power locks stopped working. i checked my fuse boxes, and didn't find anything. the locks were messing up for a while before that. when pushed it down, it would go down, then immediatly pop back up. it would do this on it's own for 2 or three times, then stop. if anybody knows what is wrong with this, please help me. i posted during the summer with no response. i was thinking about getting remote entry, and i need this to work. thank you for your help. |
Dec 10, 2006 - 11:35 PM
first check all the fuses again, there is the interior fuse box (under the dash) and one in the engine bay. Be very sure that all fuses are no blown.
next there are probably 2 things that could be wrong. One being the switch itself (the one on the door where the power window buttons are - do you have power windows or manual ?) the other is the door lock control unit. It's located under the dash near the ignition. It's a blue box if I remember correctly. That would be my guess. edit: check the B/S forum, there are a few members parting out their cars, I'm sure you could get the parts there This post has been edited by Batman722: Dec 10, 2006 - 11:37 PM -------------------- |
Dec 11, 2006 - 3:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
I had a problem like this a little while back.. It was my "door control module." Not that you have exactly the SAME problem, but could be the same module that needs replacing.
Read more about what happened with mine (with part number): http://www.6gc.net/forums/index.php?showtopic=33750&hl= edit: QUOTE(Batman722 @ Dec 10, 2006 - 10:35 PM) [snapback]509435[/snapback] the other is the door lock control unit. It's located under the dash near the ignition. It's a blue box if I remember correctly. I see now that Batman722 also said it could be the same unit that i had mentioned. And to confirm -- it is blue. -Collin This post has been edited by snapshotgt: Dec 11, 2006 - 3:48 AM -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
| Lo-Fi Version | Time is now: June 15th, 2026 - 9:31 AM |
