Dec 21, 2006 - 3:12 AM
Enthusiast ![]() Joined May 5, '06 Currently Offline Reputation: 0 (0%) |
when i start my car i hear a grinding noise and it goes away like a second after, and then i start going and thats when it gets horrible, its grinding louder than my exhaust, even with my system turned up you can still hear it, im thinking the axles but i already replaced the passenger side and it didnt do anything, and after awhile the noise goes away, know whats up?
This post has been edited by mycelicagt: Dec 21, 2006 - 11:32 AM |
Dec 23, 2006 - 1:00 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
axles are a bad start if it does it at idle like that
i'd check the starter, and umm...iunno maybe pulleys, but if it's that loud... :\ i'm a little stumped if the car seems to be normally functioning with this. -------------------- ![]() |
Dec 30, 2006 - 3:44 AM
Enthusiast ![]() Joined Nov 20, '06 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
its most likely your water pump. ive had this happen to me before. the bearing inside the waterpump errr disintergrates i think. get the water pump checked out if u can,
also a good tale tale way of knowing if it is the waterpump is that your car will run slighlty hotter then usual. that is until the waterpump dies alltogether.... |
Dec 30, 2006 - 6:44 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
my guess is a starter aswell, it it only grinding when ur turning the engine over then my guess is the starter
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Dec 30, 2006 - 1:26 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
dood im going through your same situation. I check my mounts, brakes, and crossmember, just because i recently put a new tranny on my 5s. But i think its the cv axle that are making that noise. I had my car lift and let it run up in the air at 60mph. Looking at my axle i see it vibrating real bad at the outer. I dont think im installing my axle right cause this is my 4th time replacing it.
-------------------- <--- I miss :'' ( |
Dec 30, 2006 - 1:47 PM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
QUOTE(mycelicagt @ Dec 21, 2006 - 3:12 AM) [snapback]512110[/snapback] when i start my car i hear a grinding noise and it goes away like a second after, and then i start going and thats when it gets horrible, its grinding louder than my exhaust, even with my system turned up you can still hear it, im thinking the axles but i already replaced the passenger side and it didnt do anything, and after awhile the noise goes away, know whats up? Ive worked alot on cars and the noise you seem to be hearing is 99% from a bearing/idler, it could be from any pulley alternator idler, power steering aircon. ect the part will not cost much, to find it is more of the hassle -------------------- |
| Lo-Fi Version | Time is now: July 9th, 2026 - 6:35 AM |
