Dec 21, 2006 - 11:37 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
I just wanna throw this out to see if anyone new if there is a way to fix the speedometer for our cars once we upgraded to differ size rims, tires, engine swaps, and so on...im getting tickets for speeding because my speedometer's needle is reading wrong...
Dec 21, 2006 - 11:58 AM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '06 From New Jersey Currently Offline Reputation: 0 (0%) |
wow thats a really good question.. i never even thought of that..
-------------------- "Drive Well...
...Drift Better" |
Dec 21, 2006 - 3:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
try resetting your ecu..so that it gets to "scan" your car....
Dec 21, 2006 - 3:48 PM
i want to recalibrate because i took out my speedometer needles in order to put the indiglo guages in...besides...new tires...rims...soon, damp kits, struts...all will change the speed ratio, not big change, but would be nice to be running pricisely at the correct MPH, i know they make some for the toyota tundra and tacomas...F-150...and so on, but nothing for celi...i was thinking about going to a shop and have them run my car at a constance speed while i try to put the needle at that mark...it's really going all out...but just my thought if i can't find an easier way to resolve this.
Dec 21, 2006 - 11:18 PM
Enthusiast ![]() ![]() Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
Something like that would be nice, but you do realize that most speedos dont read correct anyway. toyota pass insection as long as they dont read slower than the acctual speed. honda is 10% differnce.
-Aaron- -------------------- ![]() |
Dec 22, 2006 - 8:45 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
Dec 22, 2006 - 12:42 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
get a gps radar detector that shows you how fast you are going, jack up the front two wheels, set your cruise control then take off the needle and match it to the gps radar detector
Dec 22, 2006 - 9:22 PM
QUOTE(DeW_H0e_GT @ Dec 21, 2006 - 12:43 PM) [snapback]512226[/snapback] try resetting your ecu..so that it gets to "scan" your car.... Resetting the ECU won't do anything as far as the speedometer goes, because the speedometer is driven off of a motor which gets a signal from the speed sensor in the transmission. In fact, on the 4A-GE at least, the car will run without the speed sensor even being connected to the ECU. -------------------- New Toyota project coming soon...
Dec 23, 2006 - 1:36 PM
ill find a way...but thanks for all your inputs.
Dec 23, 2006 - 1:52 PM
your going to throw your speedo off by maybe 1-3mph by going with bigger wheels/ties. the real problem is that you are not supposed to remove your needles when doing a glow gauge install. you slide the overlays with the needles still on the cluster. if you take them off, youll never get them back to the right location. i recommend finding a few gauge cluster that has the same milage as your old one and swaping it out.
Dec 23, 2006 - 6:25 PM
it was too hard and tiresome trying to get it to work the first time by slipping it in...so i just teared it out...lol...it's okay...ill find a way
Dec 24, 2006 - 10:34 PM
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
Heres a solution for yas, my brothers mustang had a bent rear end axel so we put a V6 rear i and he got picked upt for doing 81mph when his needle said 70. Long story short we went out and I told him to drive 50mph and i followed him and then we pulled off just down the road and i told him he was doing 60mph so my recommendation is to find a friend and try several speeds to see how much your needle is off since you removed it before if nothing else works.
-------------------- ![]() Darin H. |
Dec 25, 2006 - 2:59 AM
hahaha..i thought about doing that too..,.good suggestion bro.
Dec 25, 2006 - 7:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
QUOTE(6gcSTVT @ Dec 24, 2006 - 10:34 PM) [snapback]512888[/snapback] Heres a solution for yas, my brothers mustang had a bent rear end axel so we put a V6 rear i and he got picked upt for doing 81mph when his needle said 70. Long story short we went out and I told him to drive 50mph and i followed him and then we pulled off just down the road and i told him he was doing 60mph so my recommendation is to find a friend and try several speeds to see how much your needle is off since you removed it before if nothing else works. we did this when my friends speedo stopped working altogether on his 240 sx |
Dec 26, 2006 - 11:59 AM
Enthusiast ![]() Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) |
all of you miss one thing which is that not only is your speedometer off but also your odometer.. it will show fewer miles travelled might not be a bad thing but is it legal??
in any case I use stock size rim/tires and my speedometer is deadly accurate.. I checked it with a GPS. |
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:57 PM |
