> A little gutted, Production stopped
post Dec 21, 2006 - 5:16 PM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
Hi
Well i finally save some money to buy a Apexi Power Fc with commander and go to buy one but get told that Apexi have stopped making them!!
I dont know much about ECU's so i find myself in a bit of a dilemah, i dont really trust the shops as they just want a sale and ill believe anything they say,
so if anybody would be able to suggest a ECU that is as good as or maybe slightly better than the Apexi ECU it would be much appreciated??
also is it better to have a ECU that doesnt need a air flow meter?
Thanks
Replies (1 - 16)
post Dec 21, 2006 - 6:55 PM
beno, your best bet when going with a EMS is to find a REALLY good tuner, then suit your EMS to what they specialize in.
post Dec 21, 2006 - 7:52 PM
Glitch001
Joined May 8, '06
From Irvine
removing the afm makes your car illegal here in the states but removing it frees up horsepower and gives the system their own sensors to read your car. Check out the AEM EMS w/ wideband (very common) but as pressure said find your tuner and ask what they think. If they are more familar id go that path.
post Dec 21, 2006 - 8:26 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Ok, so... that's bad news that the ST205 Power FC is discontinued!
Anybody know where there are any left? I was most definitely planning on getting one for my motor - and this ruins those plans...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Dec 21, 2006 - 10:11 PM
beno
Joined Nov 22, '05
phatty duck, try ebay as all the businesses i have emailed (including the overseas ones) dont have them anymore
Is AEM a brand name?
Is EMS another name for an aftermarket ECU?
What things would a good tuner have? just to give me a bit of a heads up
post Dec 22, 2006 - 6:48 PM
Glitch001
Joined May 8, '06
From Irvine
http://www.horsepowerfreaks.com/price/Toyo...ent_Stand_Alone
Is thge power fc from horsepower freaks, a 3s is a 3s.
AEM is a brand found here.
You could also go motec but thats like using a nuke to kill a fly. Not needed for our applications.
Good tuners will have access to a dyno, a laptop to tune, and a wideband among other things. Perhaps access to racegas if you want an agressive tune as well. and most of all experience.
the Hydra Nemesis is also an option http://mrcontrols.com/
Its not widley known so unless you know a tuner familar with it dont go that route. I have it, and im satisfied, but if I went back id go Power FC. (hell i wouldnt of used the 3s either haha)
post Dec 22, 2006 - 8:03 PM
QUOTE(Glitch001 @ Dec 22, 2006 - 6:48 PM) [snapback]512522[/snapback]
actually....a 3s is not a 3s...the Apexi versions are different and won't work correctly unless paired with the right motor....IE a ST205 Apexi should only be used on a 205 version motor, an ST185 should be used on the ST185...the different gen motors run differently..and the ECU pin outs might not be the same..
but if APEXI is gone, AEM makes a pretty good plug and play and widely used..
but as previously said
you should find a tuner first that you trust and has a good reputation.. figure out what they use the most and are comfortable with and then go with that EMS (engine management system aka an ECU)
post Dec 23, 2006 - 2:07 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
no one has mentioned the megasquirt2, but the nuke vs fly analogy may be apt in that case...
post Dec 26, 2006 - 7:32 PM
beno
Joined Nov 22, '05
How does the AEM compare the the Apexi power fc ?
post Dec 27, 2006 - 3:00 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Two very good options to go for
Link ECU...better than the PowerFC but only slightly more expensive to buy...has launch control and anti lag features etc.
if you have a little more money then the next small step up is a Hydra nemasis ECU....
beyond that cost wise your looking at Motec ECU`s but they dont offer much more than the Hydra nemesis or Link ECU`s but they are proven technology where as the other two are relitavely new.
post Dec 27, 2006 - 6:23 PM
phattyduck
Joined Dec 5, '05
From LA, CA
The Link and Hydra are both for US Gen2 3s-gte motors, correct?
A few of use are looking for Gen3 compatible ECUs (ie, no rewiring)...
-Charlie
post Dec 28, 2006 - 1:18 AM
beno
Joined Nov 22, '05
Im after a plug and play ECU as well, are the Link and Hydra not like this?
This post has been edited by beno: Dec 28, 2006 - 1:18 AM
post Dec 28, 2006 - 3:29 AM
hydra = plug and play
This post has been edited by playr158: Dec 28, 2006 - 3:29 AM
post Dec 28, 2006 - 2:48 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(playr158 @ Dec 28, 2006 - 12:29 AM) [snapback]513608[/snapback]
-Charlie
post Jan 7, 2007 - 4:51 PM
beno
Joined Nov 22, '05
does anyone know how the linkplus gen 3 compares to the other ECUs stated?
post Jan 7, 2007 - 4:58 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Both the link ECU and the Hydra nemesis are availabe for the 2nd gen and 3rd gen 3sgte, both are very good with awesome potential...especially for track days and 1/4 mile etc...I plan on getting one of those two within the next couple of weeks..probably the nemesis...the guy who makes them is very good at mapping and lives not to far from me.
post Jan 24, 2007 - 12:31 AM
beno
Joined Nov 22, '05
i can get a link plus ecu gen 2 for $516US but not sure if it is good enough ??
Lo-Fi Version Time is now: September 1st, 2026 - 11:38 PM
