Dec 22, 2006 - 8:00 PM
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
Hi everyone,
I have this weird problem with my temperature needle/gauge. Whenever I speed up 70mph and above my tempt needle/gauge suddenly begins to drop sharply to the cold mark in a matter of a second. When I let of the gas or drive below 70mph the needle suddenly returns to normal. Car blows hot air throughout this entire episode and the needle never goes up above normal/overheats. This just started this winter. I have checked and bled air out, checked for leaks, and changed the thermostat but to no avail. Any ideas what could be causing this weird problem? Shouldn't tempt go up at higher speeds and not down? I'm kinda confused:( . Thanks Eli This post has been edited by malecrod: Dec 22, 2006 - 8:02 PM -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Dec 22, 2006 - 11:41 PM
i had the same problem and fixed it by installing a new temp sensor.
Dec 23, 2006 - 12:15 AM
Hi Lagos, thanks for the reply. One question, is the tempt sensor the same as the coolant tempt sensor? Is it the sensor with the green plug behind the cold start switch?
Thanks. -------------------- 3sgteing.
Dec 23, 2006 - 12:08 PM
no its not. the coolant temp sensor with the green plug that faces the front of the car is only for the ecu. you want to replace the one fhats on the other side of that coolant neck. the one that faces the driver.
Dec 23, 2006 - 2:47 PM
Thanks all, I figured out what the problem was; This morning while looking around the engine bay, I came accross an engine sensor that is right opposite the coolant tempt sensor and when I wiggle it, it was loose. I took it off and there was broken plastic connector stuck inside of it. I believe this was preventing good contact for the tempt gauge. So after removing all the junks and some soldering and epoxy glue to keep everything tight I took the car for a test drive and the temp needle stayed where it supposed to be the entire time. Well, if anyone is having similar issue, check that sensor connection. it is right opposite the coolant tempt sensor for the 3sgte motor that is.
Now I have got one more thing under my belt: how to change the thermostat and flush and bleed air out the radiator. Thanks everyone and thanks Lagos, I appreciate your help. -------------------- 3sgteing.
Dec 23, 2006 - 2:54 PM
QUOTE(lagos @ Dec 23, 2006 - 12:08 PM) [snapback]512665[/snapback] no its not. the coolant temp sensor with the green plug that faces the front of the car is only for the ecu. you want to replace the one fhats on the other side of that coolant neck. the one that faces the driver. Thanks Lagos, that's exactly what my problem was. The connection to that sensor was loose and I guess vibration at some speeds causes to not make contact and hence the drop in tempt needle. Once again thank you. -------------------- 3sgteing.
| Lo-Fi Version | Time is now: July 7th, 2026 - 1:36 PM |
