> Installing Gauges, Oil Pressure, Water Temp troubles
post Dec 23, 2006 - 4:38 PM
jcbass7
Joined Apr 20, '06
From Florida
Searched and couldn't find what i needed.. (swap related so i posted here, sorry if it should be in the interior/elec)
I'm installing an oil pressure gauge and a water temp gauge..
they are both electric and were made by prosport.
My questions are... do i need to tap into things for the probes/senders or are there stock places i can bolt these into? Or..... should i tap the wires off of the stock sensors?
This post has been edited by jcbass7: Dec 23, 2006 - 4:40 PM
post Dec 23, 2006 - 5:32 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
both i'd suggest getting somethign to tap with
oil, i'm guessing searching will get u the part to get.
and for coolant, Greddy makes a nifty little piece w/ threading. it's a little pricey though, i'm guessing there is a cheaper route for the coolant, but that's the way i'd do it tongue.gif
post Dec 23, 2006 - 6:11 PM
jcbass7
Joined Apr 20, '06
From Florida
well i have both sender units, a temp probe thing and the oil pressure unit.. not sure where or how to connect them though..
I just finished the fuel pressure one, that was real simple
post Dec 23, 2006 - 11:46 PM
ok for the oil pressure you have 2 options...you can use the gauge to replace your stock oil pressure switch (then your low oil light on the dash would remain off) or you can get an adapter like this and use both
adapter from tunertoys
stock ^^
stock with adapter and gauge unit
for the water temp...maybe defgeph or nightryder will be around soon to drop some knowledge wink.gif
post Dec 24, 2006 - 12:39 AM
for the oil gauge.... you dont NEED the tee. you can just ditch the factory sender and screw in the one for the oil gauge. you just have to make sure the thread is metric on the prosport sender. if its not, then youll need to buy a bag of metric adapters that sunpro makes. you can find them in most car parts stores.
if it doesn't want to screw in, dont force it, cause you could damage the threads in the head and end up with a nice oil leak.
post Dec 24, 2006 - 8:14 AM
jcbass7
Joined Apr 20, '06
From Florida
Edit:
Ok so here is a pic, its the one with the yellow wire correct??
So while this is all apart where should i tap to put in the water temp sensor??
This post has been edited by jcbass7: Dec 24, 2006 - 12:33 PM
post Dec 24, 2006 - 10:07 PM
jcbass7
Joined Apr 20, '06
From Florida
i found this thread on MR2OC, but i don't want to replace the stock sensor, because then i will loose that gauge in my cluster... and it will look stupid on the C all day.. lol
http://www.mr2oc.com/showthread.php?t=1718...ater+temp+gauge
I'm guessing i can just tap the neck somewhere, but im still searching so i tap it in the right spot and don't F anything up.
post Dec 24, 2006 - 10:16 PM
hitcachi
Joined Jun 19, '05
From Nebraska
I know that you are workin on a 3S but it should be pretty similar none the less. This is from my 5S.
post Dec 24, 2006 - 10:33 PM
jcbass7
Joined Apr 20, '06
From Florida
nice nice thanks,
did you need any special adapters to transfer from metric to standard, etc.?
My only concern with the water temp being hooked in like that is i have read somewhere that the temp probe needs to be in the path of the coolant to get a more accurate reading..?
post Dec 24, 2006 - 10:56 PM
thats the way to go for a clean install for the temp gauge. you just cut your upper rad hose, put the apropriate sized adapter in there, and screw your sender into that.
for the oil pressure, if you wanna use your stock dummy light, get teh adapter dustin posted from tunertoys.
post Dec 25, 2006 - 12:51 AM
what do you think of the prosport gauges so far? hows the quality? i keep hearing good things about them, and they are priced very low.
post Dec 25, 2006 - 9:08 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(lagos @ Dec 25, 2006 - 12:51 AM) [snapback]512914[/snapback]
well i love the styling, they are exactly what i was looking for in that aspect, the directions for installation could be better, but thats not a huge issue.. one thing that is becoming a problem is how deep they are.. they barely fit into the triple pod and im afraid i will have issues with the DCW single.. i may have to cut my dash which is the last thing i want to do.
There new series of Pro gauges or what not with warning lights and the peak light seems like they would be an awesome buy.
Manny,
I was thinking about doing that with the temp sensor, i was reading about that on a miata forum, is there an easy place to buy one of those?
I plan on ditching the stock oil pressure sensor so that one is easy
EDIT:
http://www.splparts.com/
It almost costs the same as the gauge to get that adapter!!!
post Dec 25, 2006 - 10:31 AM
ebay is your friend, jesse..lol
http://cgi.ebay.com/ebaymotors/Radiator-Te...sspagenameZWD1V
post Dec 25, 2006 - 10:46 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(presure2 @ Dec 25, 2006 - 10:31 AM) [snapback]512978[/snapback]
post Dec 25, 2006 - 6:43 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
any1 kno whats the diameter of the radiator hose in mm?....1.5"?...
post Dec 25, 2006 - 7:44 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(DeW_H0e_GT @ Dec 25, 2006 - 6:43 PM) [snapback]513046[/snapback]
do you need 5sfe, 3sgte or 7afe? i have all three engines outside laugh.gif biggrin.gif
oh wait.. all three have the same size hose i think
post Dec 27, 2006 - 10:48 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(Batman722 @ Dec 23, 2006 - 11:46 PM) [snapback]512748[/snapback]
stock ^^
does that fitting fits on our op sensor?....the same thread as ours?....or are their any specific thread i need to take note b4 orderin these puppies...
btw, jcbass i measured it as 38.1 mm
This post has been edited by DeW_H0e_GT: Dec 27, 2006 - 11:18 PM
post Dec 27, 2006 - 11:46 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
i also found a new product..well not so new....
the greddy oil filter block w/ 3 outlets for the oil pressure/temp gauges...i found this is a good deal to install oil-based guages in a jiffy....
http://cgi.ebay.com/ebaymotors/GREDDY-TRUS...1QQcmdZViewItem
post Dec 28, 2006 - 11:38 AM
yea, those are pretty common too, only problem with that is clearance issues with a aftermarket DP on the 3s.
post Dec 28, 2006 - 5:35 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(DeW_H0e_GT @ Dec 27, 2006 - 8:46 PM) [snapback]513563[/snapback]
x1000 I love this thing... the block adaptor made life waaay easy to install my gauges. I hooked up both oil temp and oil pressure using this thing. I also think it could double as a source of oil for a turbo for those boosting NA motors. I also seen similar products for people who have LS motors in their integra who want to run a b16 head, for LS Vtec otherwise you would tap into the head for oil... greddy FTW!
QUOTE(presure2 @ Dec 28, 2006 - 8:38 AM) [snapback]513645[/snapback]
if you use a K&N oil filter you will have no problem. It is REALLY tight but there is just enough room to remove and replace the oil filter back on. wink.gif
Lo-Fi Version Time is now: August 12th, 2026 - 12:35 AM
