Dec 29, 2006 - 9:02 AM
![]() Enthusiast ![]() ![]() Joined Jan 6, '05 From Finland, Turku Currently Offline Reputation: 0 (0%) |
So few days ago i speeded on the ramp to the highway and was feeling like theres not that much power i should have. Kind of lost some traction on high rpms. Then just drived normally without any problems and few hours later speeded again and the same problem camed. So took it to a little testdrive and found that theres something missing on the +5k rpms. On the low rpms it works all fine but when i hit it to 5k it doesnt speed well and sounds little too loud and kind of wierd. I think it might be some problem on the air but couldnt found anything myself so wondered if you 6gcers have some idea of what i should look at?
Btw i now its not 3sgte so it doesnt supposed to speed too well anyway but atleast my 3sge should go little faster than this. I think im not gonna keep up with some 1.6litre corollas. -------------------- Please visit on our teams new website. hrp-tuning.com
![]() 19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio |
Dec 30, 2006 - 3:38 AM
Enthusiast ![]() Joined Nov 20, '06 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
check your air intake, may have a loose connection/pipe or somethings fallen off.
you may also have an exhaust leak somewhere in your exhaust system. give some more info on what happens and what it sounds like, what it feels like when it happens etc. |
Dec 30, 2006 - 5:51 AM
It feels like its somehow choking on higher rpms. And it feels like its trying to search the right rpms and just couldnt find it when your engine is just running. Thats pretty much all i can say. And ive already checked all the intake pipes and so on. Thanks in advance.
Dec 31, 2006 - 1:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
if it's anything like the 5sfe, the powerband is just in lower RPMs. once you get past 5K rpms the car just doesn't make as much power as it does in the lower RPMs, so it feels like it's dragging. I don't know much about the 3sge though, so I don't know.
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 1, 2007 - 11:06 AM
Enthusiast ![]() Joined Apr 16, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
QUOTE(6strngs @ Dec 31, 2006 - 1:29 PM) [snapback]514240[/snapback] if it's anything like the 5sfe, the powerband is just in lower RPMs. once you get past 5K rpms the car just doesn't make as much power as it does in the lower RPMs, so it feels like it's dragging. I don't know much about the 3sge though, so I don't know. So true, my car just doesn't go if i go any higher than 3k -------------------- |
Jan 1, 2007 - 11:15 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(6strngs @ Dec 31, 2006 - 7:29 PM) [snapback]514240[/snapback] if it's anything like the 5sfe, the powerband is just in lower RPMs. once you get past 5K rpms the car just doesn't make as much power as it does in the lower RPMs, so it feels like it's dragging. I don't know much about the 3sge though, so I don't know. Wel its nothing like that, 3S-GE is fun till 5k rpm, and only gets BETTER when going up to around 7200 rpm. So if the car hold back or doesn't accelerate faster then it did below the 5k rpm barrier, then there is something wrong. Did you check your ignition system? Spark plugs/wires, distributor/rotor, coil. My car stuttered alot in higher rpm regions because of a worn coil->distributor wire the was oxidized. Check your O2/Lamda sensor. -------------------- JDM Powerplant installed, BPU coming very soon!
Jan 1, 2007 - 12:11 PM
Thanks kadett. What im also personally thinking now are the spark plugs. Sounds pretty much like it after checking it up with my friend. Going to get new sp's tomorrow and also a new gasfilter, oilfilter and some decent oils too.
| Lo-Fi Version | Time is now: May 7th, 2026 - 3:28 PM |
