Dec 30, 2006 - 1:43 PM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Ok.. I had aamco install the LSD on my e153.. here is the info
99 camry v6 5spd 95 jdm mr2 vlsd Ok.. I took my trans to aamco and told them to install the mr2 diff.. the differential had the speedo gear on it already.. Reason I mention this is because my speedo started to work erradicly lately.. and I was fearing what I found out today.. I pulled the speedo unit out of the trans and the gear teeth on the unit were worn down to ****.. Also when I turn the wheel even the slightest bit to the left or right (especially the left) i get a grinding noise.. Now when I helped my buddy work on his WRX trans.. we put the differential in wrong.. didn't set the proper preload and he had the EXACT same noise as I am getting... then he had subaru set it up and all was well. I'm just wondering if there is anything I could've screwed up myself during the install of the trans/axles that may of I dont' know.. shifted? the differential or something... cuz I can't come up with anything.. I don't know WHY the gear teeth on the speedo are worn down to nothing either.. how the diff might've been installed wrong to cause that I don't know.. any idea's? The differential came with the speedo ring gear only.. I gave aamco an alltrac diff to take the drive gear off of that to put on the mr2 LSD.. which they did.. atleast I think.. cuz they gave me the alltrac diff back minus the drive gear.. So as far as I can tell I don't think I screwed anything up on my end.. but any idea's on this would be helpful. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Punisher E153 w/ LSD issue Dec 30, 2006 - 1:43 PM
phattyduck QUOTE(Punisher @ Dec 30, 2006 - 10:4... Dec 30, 2006 - 3:00 PM
Punisher QUOTE(phattyduck @ Dec 30, 2006 - 3... Dec 31, 2006 - 4:46 AM![]() ![]() |
| Lo-Fi Version | Time is now: March 19th, 2026 - 10:51 PM |
