Dec 31, 2006 - 1:33 PM
Enthusiast Joined Dec 31, '06 From Woodlands Currently Offline Reputation: 0 (0%) |
Ok so first I'd like to say hi Im new here, I read the rule thing briefly and did try searching my topic before posting so if I did this wrong Im sorry. Ok so I bought my celica about 9 months ago and love it. Its a 95 hatchback with 140k miles, The one issue I wanted to ask about was if any of yall had problems with the engine temp gauge. Ever since I got my car the temp gauge has been out of whack sometimes it doesnt read at all and sometimes it reads a little
Dec 31, 2006 - 4:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
It sounds to me like your thermostat is probably stuck open. Have the thermostat replaced.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Dec 31, 2006 - 5:45 PM
QUOTE(Dr_Tweak @ Dec 31, 2006 - 9:09 PM) [snapback]514259[/snapback] It sounds to me like your thermostat is probably stuck open. Have the thermostat replaced. -Doc I'll try that, thanks |
Dec 31, 2006 - 7:59 PM
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
Like Dr. Tweak (Doc) said, replace the themostat. Also you can check the sensor for the temp gauge, it could be bad sensor or bad connection.
-------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Jan 8, 2007 - 11:07 AM
Enthusiast ![]() Joined Oct 23, '06 From wilson Currently Offline Reputation: 0 (0%) |
mine did the same thing that urs is doing. it would never give an accurate reading so i didnt worry about it cause my car wasnt acting funny at all. Exactly one week after i bought my celica i blew the motor cause it over heated. Id get it fixed fast
Jan 8, 2007 - 11:11 AM
Enthusiast ![]() Joined Jan 8, '07 From new jersey Currently Offline Reputation: 0 (0%) |
Mine was doing the same exact thing it has about 120k miles on it but that temp sensor costed me a new radiator which was really bad because that was ridiculous to find(i ended up gettin the new sender at autozone) didnt have much problems with the thermostat but sounds like you should replace it!!
| Lo-Fi Version | Time is now: July 29th, 2026 - 6:41 AM |
