> Are the Gt and St front calipers the same?
post Jan 2, 2007 - 7:27 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ok.. I should know better than to ask, but i couldnt find a def awsner. so..
Are the Gt and St front calipers the same? I have gt calipers, And I need to replace one of my front ones on my ct celica. Thanks for the help
Doug
post Jan 2, 2007 - 7:37 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
i dont know for sure but if you have a GT, stick with GT parts, why take the chance of downgrading if their not the same
post Jan 2, 2007 - 7:41 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(illneversellmycelli @ Jan 2, 2007 - 7:37 PM) [snapback]514687[/snapback]
Oh my bad, I drive an ST, but have a gt parts car
I could just swap over everything but im not sure if i want to do all that.. or how much work it would be
post Jan 2, 2007 - 7:49 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
well the gt has the bigger engine so it would make sense to have bigger brakes, someone is bound to know for sure on here
post Jan 2, 2007 - 8:14 PM
GT and ST front brakes are different. You would need the GT calipers, rotors and pads and they will bolt up to the ST hub perfectly. The ST lines will work just fine with the GT fronts.
post Jan 5, 2007 - 12:22 PM
jc47
Joined Nov 10, '06
From Cleveland
I got gt calipers once by mistake and they did not fit. The holes for the mounting screws were not in the same location.
post Jan 5, 2007 - 12:45 PM
Nemises
Joined May 6, '04
From antioch CA
QUOTE(Batman722 @ Jan 3, 2007 - 1:14 AM) [snapback]514695[/snapback]
You need the caliper bracket also the Gt caliper wont bolt to the st bracket.
Lo-Fi Version Time is now: September 19th, 2026 - 11:11 AM
