Jan 3, 2007 - 1:12 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Is the cold start time switch interchangeable between the 5sfe engine and the 3's?
I was trying to change them around yesterdaybut could only get the connector end to come off. How do you take the actual sensor out of the coolant neck? How do you test to see if its faulty? IIRC you connect it to an ohm meter and it should be between 2-4 ohms. Is that right? |
| Lo-Fi Version | Time is now: March 23rd, 2026 - 8:11 AM |
