Jan 3, 2007 - 1:42 PM
Enthusiast ![]() Joined Sep 21, '06 From New York City Currently Offline Reputation: 0 (0%) |
I have a 94 gt. Dropped with h&R springs and KYB shocks rear and front.
I took it to get alighned and they said because of the drop the camber is off slighly. I have the upper mount of the springs with a preset camber adjustment. Is there something else i can do to adjust it better. What do you guys have. Even after the alighnment the car still turns towards the right. -------------------- ![]() |
Jan 3, 2007 - 1:44 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Get some "crash" alignment bolts to allow camber adjustment
Jan 3, 2007 - 1:58 PM
QUOTE(bufferdan @ Jan 3, 2007 - 1:44 PM) [snapback]514828[/snapback] Get some "crash" alignment bolts to allow camber adjustment Sorry I dont know what you are talking about? What is a crash alignment bolt? How do you install them. Thank you -------------------- ![]() |
Jan 3, 2007 - 2:15 PM
I found this online
These bolts are used for crashed cars that have suspension damage and cannot be returned to stock camber. The bolts are available in three sizes: 1 Dot, 2 Dot and 3 Dot. The part numbers are as follows: 1 Dot 90105-15004 2 Dot 90105-15005 3 Dot 90105-15006 Each successive bolts will change front camber by -0.5 degrees. I used 2 Dot bolts in my car to get close to the camber I wanted, since 3 Dots would give me more than I wanted. The alignment I ended up settling on was as follows: Has anyone done this? Then, how did you get the proper alignment? -------------------- ![]() |
Jan 3, 2007 - 2:35 PM
get a set of CUSCO upper pillow mounts for the front
http://www.japanparts.com/Pic/pic075/058.htm http://www.japanparts.com/db/partslist.php...er=&volkey= |
Jan 3, 2007 - 4:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
Just get the eibach or obx camber adjustment bolt...its basicly bolts with cams on them.
![]() Its what I have and my alignment is all in specs now(mind you I installed the bolt myself using my eyes as aligment! lucky sob). This post has been edited by Rayme: Jan 3, 2007 - 4:54 PM -------------------- ![]() -Rémy 02 SiR, 08 250R |
Jan 3, 2007 - 10:35 PM
QUOTE(Rayme @ Jan 3, 2007 - 4:51 PM) [snapback]514878[/snapback] Just get the eibach or obx camber adjustment bolt...its basicly bolts with cams on them. ![]() Its what I have and my alignment is all in specs now(mind you I installed the bolt myself using my eyes as aligment! lucky sob). Thank you for the help. This is what I found I hope it works well. IEC-35450 Adjustable Camber Kit, Eccentric Bolts, 17mm, Toyota/Lexus/Pontiac/Scion, Front, ![]() Ingalls Engineering Co Not all camber kits are created equal! These adjustable camber kits from Ingalls Engineering have a Posi-Change feature, allowing camber changes up to 3 degrees positive. Each block displays a vertical line above the bushing that represents a 2 degree positive change. Don't trust your wheel alignment to just anyone--Ingalls has been producing camber kits for over 20 years, and you can be assured that you're getting a quality product -------------------- ![]() |
Jan 11, 2007 - 10:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
I got a pair of 2 and 3 dots from Toyota for 20 bucks
Mar 1, 2009 - 4:48 AM
Do camber kits work only because they are skinnier bolts and you can adjust the angle? thats what it looks like.
| Lo-Fi Version | Time is now: August 29th, 2026 - 12:50 PM |
