Jan 3, 2007 - 4:31 PM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
MR2 Spyder Lightweight Lifter Conversion in 3SGTE
I found this out from a friend that did the same thing and was happy with the result Now I am going to do the same The stock bucket weighs 1.6 oz. & the MRS weighs 1.03 oz. That is a weight savings of 35.5%. When high lift cams are used with stock(2nd gen) lifters it has caused the shims that are used for adjusting cam/lifter clearance to fly out. This eliminates that by eliminating the shim all together. That lightens the valvetrain weight and allows higher RPM limits. The MRS bucket eliminates the shim. You have to buy the bucket in different thicknesses to set your own clearances. Hope you All like the info PS Next week I start up for the frist time in about 2 years. This post has been edited by Alan: Jan 3, 2007 - 4:32 PM -------------------- |
Jan 3, 2007 - 4:36 PM
shimless bucket conversions have been around for a long time....
but to my knowledge high lift cams don't fit into a 2nd gen head.... http://www.mr2oc.com/showthread.php?t=8478...cket+conversion This post has been edited by playr158: Jan 3, 2007 - 4:56 PM |
Jan 3, 2007 - 4:41 PM
QUOTE(playr158 @ Jan 3, 2007 - 4:36 PM) [snapback]514873[/snapback] shimless bucket conversions have been around for a long time.... but to my knowledge high lift cams don't fit into a 2nd gen head.... That is why I am going to try it out ASAP, ill make a post on how it is done also in the how to do section -------------------- |
Jan 3, 2007 - 8:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
Hmm theres plenty of 1ZZ'd Prizm in the junkyard I wonder o.O!
| Lo-Fi Version | Time is now: May 10th, 2026 - 3:23 PM |
