Jan 5, 2007 - 9:49 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Hey guys, I am looking for some advice as to buying an air compressor.
I know I read somewhere that said you shouldn't get any less than about a 20 gallon tank and it should do a minimum of 5 cfm at 90 psi for it to be good for an impact wrench and pneumatic tools. I guess I am looking for advice from you guys as to what you have for air compressors and what your thoughts are for minimum specifications. Right now I need to buy the air compressor to work on my house (hardwoods and brad nailer for baseboards), but I don't want to buy an air compressor that won't be good for working on the vehicles down the road. Let me know what your thought are. Thanks. David -------------------- |
Jan 5, 2007 - 10:41 AM
a) wrong section
b) craftsman 26 gal. is wat i have and use it for everything |
Jan 5, 2007 - 11:41 AM
Ya I suppose it should be in general discussion.
I was sort of thinking maintenance since it would be used for maintenance of vehicles. -------------------- |
Jan 5, 2007 - 12:01 PM
Enthusiast ![]() Joined Nov 10, '06 From Cleveland Currently Offline Reputation: 0 (0%) |
It really depends on exactly what you will be using it for. For nailers and impact wrenches, you really don't need a big compressor, and you may want to get a smaller one since it will be more portable (can fit in trunk, etc.). Tools like drills, sanders, cutters, etc. are the ones that really use a lot of air; these will usually use a lot more than 5cfm at 90psi. Most tools list the air flow requirements right on the box, you can usually get by with a little less if you don't mind waiting for the compressor to pump up.
Also, if you ever plan to do any painting, make sure you get an oil less compressor. |
| Lo-Fi Version | Time is now: May 16th, 2026 - 9:40 AM |
