> S-AFCII Initial Setup
post Jan 10, 2007 - 2:25 PM
94celicadude
Joined Mar 28, '04
From St.Louis
ok, i just bought an S-AFCII for my 94 ST, its a 5spd, i have a few questions for the initial setup part of installing this gadget. First of all, what kind of sensor does the 7afe have? they give me a choice of 4: Hot wire, Flap, Pressure or Karman. And also how many? one i am guessing, but then again this is why i seek the expert advice from you all. Thanks a lot in advance.
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Jan 10, 2007 - 3:01 PM
P5ycho
Joined Mar 29, '06
From UK
for initial setup all you need to do is setup the type of sensor,
on the celi is a Pressure sensor,
which on the selection page is option 3
then select the option page and set the sensor as 01 in and 01 out
car should run fine after that...
post Jan 10, 2007 - 3:15 PM
94celicadude
Joined Mar 28, '04
From St.Louis
perfect, that is exactly what i wanted to know. Thank you very much.
1994 GT Hatchback
1994 ST Coupe
1999 Corvette
post Jan 11, 2007 - 10:42 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
is it possible to tune the fuel yourself without having to take it to a shop and have them dyno tune it?
-Alex {](O_o)[}
post Jan 11, 2007 - 10:48 PM
94celicadude
Joined Mar 28, '04
From St.Louis
well im pretty sure it is, i think my dad and i are going to give it a shot initially but we then are going to take it to a dyno. If you have a previous dyno chart that has the appropriate A/F ratio and the stocheometric line at the bottom of the graph, you can tell at approx. which points the engine is either too lean or too rich, and use the AFC to correct that, now doing it just by looking at a sheet of paper and hpoing it works is not the best, and you wont get max power output, and also there is a good chance you run too lean and damage your engine, but i think it is possible to tune to a certain degree yourslef, not recommended. The best would be to have a dyno so you cna make a run after each change and see where it stands.
1994 GT Hatchback
1994 ST Coupe
1999 Corvette
post Jan 11, 2007 - 11:18 PM
thats the only way to do it right.
post Jan 12, 2007 - 12:07 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
aah ok. thanks. that's gonna set me back a few $$, but it'll be worth it in the name of power.
-Alex {](O_o)[}
post Jan 15, 2007 - 12:07 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
quick question, does the RPM reading on the S-AFC2 read lower than what your actual tach says? Mine's doing that and I don't know if that's normal....
-Alex {](O_o)[}
post Jan 15, 2007 - 2:30 PM
P5ycho
Joined Mar 29, '06
From UK
i would just check where you ave taken the rpm reading from, ie where u have connect the rpm wire.
i believe there are 2 points at the ecu where u can do that.so it might be the case of connecting it to the other point.. and u can use the same wire to monitor the injector signal too.
if u want it to read exactly the same as your tach then i would extend the wire and connect it behind the tach itself...
This post has been edited by P5ycho: Jan 15, 2007 - 2:31 PM
post Jan 15, 2007 - 5:41 PM
QUOTE(NgoFcukinWay @ Jan 15, 2007 - 12:07 AM) [snapback]517860[/snapback]
it is not normal.
the SAFCII's RPM wire should be hooked up to the IGF signal from the ECU.
i would check your wiring.
post Jan 15, 2007 - 9:43 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
n/m. it's reading normal. it was like that before i changed the settings to match the car. didn't get a chance to post back up once i got it changed. Thanks though!
-Alex {](O_o)[}
Lo-Fi Version Time is now: May 24th, 2026 - 3:42 PM
