Jan 10, 2007 - 8:26 PM
Enthusiast ![]() ![]() ![]() Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) |
okay so liek 2 weeks ago i installed my new sound system:
Alpine Headunit 15' Type R' sub Hifonics Brutus Amp 1,200 rms....supposedly it freking pounds the **** out of my car! its jsut pure vibrations and thumps. however its not a friendly fit in the coupe. i had to remove the spare tire to create...liek a divit for it to fit. but anyway it pounds..alot and how its set up now, i finally got it turned around so its sitting how most ppl have their subs positioned ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() so it pretty much takes up the whole trunk. and like i said, its no longer positioned like that anymore This post has been edited by KB-2: Jan 10, 2007 - 8:28 PM -------------------- ![]() KB |
Jan 10, 2007 - 8:43 PM
![]() Enthusiast ![]() ![]() Joined Jul 22, '06 From San Antonio / georgetown, Texas Currently Offline Reputation: 9 (100%) |
niiice that looks awesome, and the box is huge.
Jan 10, 2007 - 9:22 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
wow that fits perfect!!
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 10, 2007 - 9:53 PM
yea...the box was a lil bigger than i visualized....
right now i have it pointing towards the front seats, so it gets pretty darn loud, especially with the seats down -------------------- ![]() KB |
Jan 10, 2007 - 10:39 PM
Enthusiast ![]() ![]() Joined Sep 28, '06 From Montreal, QC, Canada Currently Offline Reputation: 2 (100%) |
If you point it towards the licence plate, it'll be louder. It should anyway. I haven't had experience with the acoustics of a celica yet, but in theory that's where it'll be loudest.
This post has been edited by GTSOwner: Jan 10, 2007 - 10:40 PM -------------------- One o'dem crazy Canadian freaks, eh?
Jan 10, 2007 - 10:55 PM
really?
i thought it would be louder facing the front cause it ahs more airspace and more air to move or wahtever? -------------------- ![]() KB |
Jan 11, 2007 - 2:07 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
^face it to rear because the sound waves bouce off the back and produce a stonger sound. you face it towards the front and more airspace=less defined sound/weaker response.
Jan 11, 2007 - 7:18 AM
In theory, it's because no matter what direction you point the box, the soundwaves are going to radiate from every direction, incuding the direction opposite to where the cone is facing. By putting the cone facing to the rear, your sound waves bounce back almost immediately and are in much closer phase with the waves radiating from the back of the box. Otherwise, they are not quite in phase and cancel each other out a bit resulting in lower apparent sound levels.
I'll try to find the article where I read that (been a couple years). -------------------- One o'dem crazy Canadian freaks, eh?
Jan 11, 2007 - 9:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
Nice
Jan 11, 2007 - 12:12 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
Nice... but too big haha... it wouldn't fit my sports gear! I used to do 2 10" in my dsms...! But looks nice!
Jan 12, 2007 - 2:24 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I believe, and you can correct me if I'm wrong, that the actual sound from a subwoofer actually comes out the back, and not the front. which is why facing it away from the driver makes it louder. also the reason why the box itself affects the sound/volume of it.
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 12, 2007 - 2:36 AM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
QUOTE(GTSOwner @ Jan 12, 2007 - 1:18 AM) [snapback]516994[/snapback] In theory, it's because no matter what direction you point the box, the soundwaves are going to radiate from every direction, incuding the direction opposite to where the cone is facing. By putting the cone facing to the rear, your sound waves bounce back almost immediately and are in much closer phase with the waves radiating from the back of the box. Otherwise, they are not quite in phase and cancel each other out a bit resulting in lower apparent sound levels. I'll try to find the article where I read that (been a couple years). Correct. Actually, the best setup(tested by a guy with published results) is a subwoofer positioned against the rear . Here for details: http://www.teamrocs.com/technical/pages/aiming.htm As for subwoofer sound. Any speaker will have a sound wave behind and in front of it. After all, it is just a cone(paper etc) vibrating away. The box air volume acts sort of like a car shock, it "controls" cone movement which is why many people say that you can easily blow subs(not designed for freeair) if you run it free air because it doesnt have the resisting force from the air volume in the box anymore. This also brings about the use of thick mdf for box construction(18mm>), not only is it vital to have a non flexing box.... it also helps prevent the backwave of the sub from destructively interfering with the front waves which will cause cancellation.(same theory applies to door speakers) and yea I have nothing better to do now This post has been edited by soven: Jan 12, 2007 - 2:38 AM |
Jan 12, 2007 - 7:20 AM
alrihgty then.....ill go flip that bad boy around later!
my friend also jsut got a new system recently in his jeep, hes got 2 12' kickers....i think crv's?? or anyway they are jsut the basic ones....and they were...wow crazy bass, i was very suprised. i think for my next set up...which wont be for a while...will be some type of kickers...im feeling L7's or whatever they are called..get 2 12's......but my only questions is.....can i use One Mono Amp to power 2 subs? or even better can i sue Two Mono amps to power two subs (one amp per sub?) if the subs are in the same box..... -------------------- ![]() KB |
Jan 12, 2007 - 8:11 AM
You can use one mono to power as many subs as you want as long as the resistance presented to the amplifier does not drop below what the amp can handle. Can also use two monos for two subs in the same box as long as the subs and amp are the same model.
Jan 12, 2007 - 11:03 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
awesome man... glad to see u got that amp... thats actually the same I have in right now... so im sure that 15 pounds... even my 2 12's sound crazy and will make me lose hearing
Jan 12, 2007 - 6:20 PM
Enthusiast ![]() ![]() Joined Dec 22, '06 From Caracas-Venezuela Currently Offline Reputation: 5 (100%) |
that's kind o huge.... i'll post mine pics later...
-------------------- Celica ST202
Jan 12, 2007 - 6:42 PM
Enthusiast ![]() Joined Sep 30, '06 From Knox Vegas, Tennessee Currently Offline Reputation: 0 (0%) |
You could cook some mean stir fry in that sub I betcha.
Jan 12, 2007 - 6:59 PM
QUOTE(soven @ Jan 12, 2007 - 2:36 AM) [snapback]517287[/snapback] QUOTE(GTSOwner @ Jan 12, 2007 - 1:18 AM) [snapback]516994[/snapback] I'll try to find the article where I read that (been a couple years). Correct. Actually, the best setup(tested by a guy with published results) is a subwoofer positioned against the rear . Here for details: http://www.teamrocs.com/technical/pages/aiming.htm AWESOME! That's the exact article I was looking for!!! -------------------- One o'dem crazy Canadian freaks, eh?
Jan 12, 2007 - 10:12 PM
alrihgt, i turend the woofer around earlier today...took some custom fabrication....consisting of a pillow..and a piece of wood
due to i ahd ot remove the spare tire ot make it fit how it is.....obviously there was a large dip i nfloor, so the woofer would be bashing up againts the wall if i dint support it somehow, so i jammed a big pillow in the crater to fill it up, and then locked it in place with a piece or 2 of solid wood....dont woordy its not visible. didnt get a chance to test the sound diffrence yet however... -------------------- ![]() KB |
Jan 16, 2007 - 6:45 PM
okay so yes it is deff WAY louder with it facing the license plate...wow
so if you dont already, turn your stuff around! -------------------- ![]() KB |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 8:36 PM |
