> oil leak need help
post Jan 19, 2007 - 8:08 PM
rspjean
Joined Aug 20, '06
From Kissimmee
i got a new problem my friend showed my that the bolts on my valve cover were loose so i tightened it but i tightend it so much that when i took off the wrench the screw had gon through the bolt and this is what happend in my engine now anyone got those bolts?
Replies (1 - 6)
post Jan 19, 2007 - 10:48 PM
jc47
Joined Nov 10, '06
From Cleveland
As long as the studs are ok, you should be able to remove the nuts, clean the threads and nuts, apply some gasket sealer or rtv silicone to the threads and reassemble. Note that you also probably need new sealing washers and valve cover gasket. The nuts aren't supposed to be very tight; I would use a torque wrench to avoid damage.
post Jan 19, 2007 - 11:02 PM
for the nut, it's part # 90176-06028 about $ 1 each
and the seal washer, part # 90210-06010 about $ .50 each
post Jan 19, 2007 - 11:09 PM
rspjean
Joined Aug 20, '06
From Kissimmee
where would i order this ?
post Jan 19, 2007 - 11:33 PM
you could get them from any local Toyota dealership, just give them the part #s. Also you could order them from an online Toyota dealership but you would have to pay shipping. You dig ?
post Jan 20, 2007 - 12:11 AM
rspjean
Joined Aug 20, '06
From Kissimmee
so i just go to any toyota dealership and they will order it for me and call me when they have em ?
post Jan 20, 2007 - 2:14 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE(rspjean @ Jan 20, 2007 - 12:11 AM) [snapback]519427[/snapback]
correct unless they have them in stock then and there.
-Alex {](O_o)[}
Lo-Fi Version Time is now: August 29th, 2026 - 4:31 PM
