4 Pages V   1 2 3 > »
> water/methanol injection installed!, like art said, smurf piss FTW!
post Jan 20, 2007 - 8:30 PM
hey guys, got my Devils Own water/methanol injection kit installed this afternoon, with a 3GPH nozzle, art had told me how much he liked his, so i went ahead and got one. smile.gif
i basicly installed it the same as art, very easy to install.
the best way for me to discribe it is that the car feels like it did when i mixed in the race gas. no hesitating, nothing, just pure power, thruout the RPM band...AND,..i turned the boost back up....
..and i havent even touched the emanage yet..
once i get the EM ultimate a bit better fine tuned, ill head back to the dyno to see what it makes on pump, with the smurf piss. i anticipate it will be very close to the race gas mix #s, which would be awesome.
post Jan 20, 2007 - 8:48 PM
alltracman78
Joined Aug 9, '06
From Ma
Damn dude.
That's awesome.
I definitely need to look into this once my engine/clutch are all set...
post Jan 20, 2007 - 9:26 PM
glad it worked out well for you manny! post your install pics!
post Jan 20, 2007 - 9:54 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
Thats it i'vs seen enough... my h2o/meth kit has been ordered biggrin.gif
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Jan 21, 2007 - 3:27 AM
manny. next time you go for a ride, let us know how much if a change you see in your egt temps. im willing to bet they dropped at least 100degs.
post Jan 21, 2007 - 4:46 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Jan 21, 2007 - 5:48 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Also interested in this, but will wait after all the BPU parts are installed.
post Jan 21, 2007 - 6:31 AM
QUOTE(lagos @ Jan 21, 2007 - 3:27 AM) [snapback]519661[/snapback]
ill have to get back to you on that art, my egt gauge is hanging in my engine bay right now...my exhaust manifold that has the EGT bung in it is back @ finishline coatings getting recoated.
post Jan 21, 2007 - 1:37 PM
finally getting recoated !! great
when you get that back we will put that back in, I'll see you tonight Manny
post Jan 21, 2007 - 2:41 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
awesome! love WI. im glad we have people testing it now.
post Jan 21, 2007 - 3:16 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(presure2 @ Jan 20, 2007 - 8:30 PM) [snapback]519573[/snapback]
Awsome, will definatly do it on my next project biggrin.gif.
How much boost would you be pumping in for raceing not daily driving, and with maybe some race gas wink.gif
post Jan 22, 2007 - 2:55 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Manny - Is your 5S-FTE still on stock internals?
post Jan 22, 2007 - 3:20 PM
QUOTE(Negative @ Jan 22, 2007 - 2:55 PM) [snapback]520057[/snapback]
yes it is
post Jan 22, 2007 - 3:58 PM
Negative
Joined Apr 28, '04
From Houston, Texas
His project gives me such hope - and he gives me such good advice. I think I would have just swapped long ago if not for his results.
Thanks Manny and thanks batman722 for the answer.
post Jan 22, 2007 - 4:59 PM
QUOTE(Alan @ Jan 21, 2007 - 3:16 PM) [snapback]519757[/snapback]
with the meth injection, i can run up to my map sensors limit ~15psi, before fuel cut hits.
yea, no internal upgrades on the motor, and as it stands, i have no plans to, or reason to.
post Jan 22, 2007 - 5:58 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Which map sensor are you using? The 3s 2bar map is still good to use right?
post Jan 22, 2007 - 11:44 PM
6strngs
Joined May 12, '06
From Wilmington, NC
hmm, I'm curious now. could a water/methanol injection kit be used instead of an intercooler on a turbocharged set-up? also, could it benefit a NA engine?
post Jan 23, 2007 - 2:09 AM
rzanology
Joined Apr 25, '05
From nyc
where are you guys getting this kit from??? ebay?
post Jan 23, 2007 - 2:13 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(rzanology @ Jan 22, 2007 - 11:09 PM) [snapback]520330[/snapback]
probably http://www.alcohol-injection.com/
post Jan 23, 2007 - 3:11 AM
QUOTE(6strngs @ Jan 22, 2007 - 11:44 PM) [snapback]520296[/snapback]
yes. you can run WI instead of an intercooler. sabb even had a production car that was cooled by water injection alone. i think some supercharger guys use it instead of an IC too.
but for our cars, you should have at least a front mount. its a little too risky to just rely on WI for all your cooling needs. an fmic with WI is the way to go.
as far as an NA car goes... you wont see much benefit. most 4cyl NA motors and tuned to run on normal pump gas and dont have to deal with the very high cylinder temps that a turbo adds.
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: September 12th, 2026 - 8:18 AM
