Jan 21, 2007 - 3:43 PM
Enthusiast ![]() Joined Jan 2, '07 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
I recently bought a 97 Celica GT Convertible. I decided to give the car a complete tune up, being that it is at 80K miles. I have the car half way apart trying to change the timing belt & water pump, & I cannot get the crank pulley bolt out. It is really on there.
I am following the directions in the book I have, jamming a screwdriver in the hole & using a prybar to keep the crank from spinning. I can keep the crank from turning well enough. My problem is this bolt will just not come loose. I even went out & bought a $160 craftsman impact wrench, that is supposed to put out 700 ft/lbs of torque. The bolt refuses to move. Is there some trick to this? I sprayed it down with PB Blaster yesterday, last night, & again this morning. Any one have any suggestions? How tight is this crank bolt supposed to be anyway? It isn't reverse threaded is it? |
Jan 21, 2007 - 3:49 PM
Enthusiast ![]() Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I ended up using a 4' cheater pipe and 1/2" drive ext (sticking out of the wheel well) PB works good, make sure your impact is in reverse, yep it happens.
Jan 21, 2007 - 7:02 PM
QUOTE(56willysnut @ Jan 21, 2007 - 3:49 PM) [snapback]519762[/snapback] I ended up using a 4' cheater pipe and 1/2" drive ext (sticking out of the wheel well) PB works good, make sure your impact is in reverse, yep it happens. X2 a nice long section of pipe over a 24" breaker bar..the heavier you are, the easier it gets from there...lol -------------------- Former Team 5SFTE pro member ;)
Jan 21, 2007 - 10:04 PM
I got it off finally. My problem was I was cheap. The cheap little spiral hose that came with my ir compressor wasn't big enough to supply the air needed to run the impact wrench. Amazing what you learn when you read the manual. It came right off when I connected a 3/8" hose. Read the freaking book. My old Impact wrench probably would have worked.
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:03 AM |
