> minor transmission problem, more annoying than anything else
post Jan 23, 2007 - 11:28 PM
celicamike
Joined Dec 26, '05
From So Cal
Hey guys, I changed the gear oil in the manual transaxle of my '94 GT, and it started to grind a little bit going into third gear. This only happened for a few minutes until the car was warmed up, then everything would be fine. Anyway, I thought the problem might be due to me using synthetic gear oil so I changed it back to conventional, but the same thing is still happening. Any ideas? I'm using the recommended SAE 75W 90. I would appreciate some help. Thanks
Replies (1 - 12)
post Jan 24, 2007 - 12:21 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
http://www.club3g.com/forum/showthread.php?t=82585
post Jan 24, 2007 - 7:58 AM
dan85204
Joined Jul 23, '06
From MASS
mine does the same thing, but only when i down-shift into 3rd. it's a quick grinding sound that sounds unhealthy. i changed my gear oil last summer, and that did a little, but the only real solution i found so far was double clutching.
post Jan 24, 2007 - 8:30 AM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
the syncros are not right, mine does it and i got that response from several of teh readers on here b/c it happened to them
post Jan 24, 2007 - 9:43 AM
95CelicaRacer
Joined Jan 22, '07
From North Carolina
Did you make sure if you filled it up to the bolt hole where you fill it up at?
post Jan 24, 2007 - 6:19 PM
celicamike
Joined Dec 26, '05
From So Cal
QUOTE(95CelicaRacer @ Jan 24, 2007 - 9:43 AM) [snapback]520789[/snapback]
It's filled to the proper level
post Jan 24, 2007 - 10:58 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
All you need is some pennzoil synchromesh oil. It is slicker than what is recommended and lets worn synchros work like new. I had the same problem in my celica and it totally disappeared. I have posted this before and it works. You might have to order it off the internet as it can be hard to find. So enjoy this easy fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
post Jan 24, 2007 - 11:07 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Mine did the same thing for 10 months. When cold it grinds. when it hot its fine. I put the 3sgte in the car and changed the gear oil. 1000 miles later its stuck in 5th and car wont move. Im not saying this will happen to you, just something to think about. wink.gif
post Jan 25, 2007 - 6:24 PM
celicamike
Joined Dec 26, '05
From So Cal
I'm gonna try that synchromesh oil, let you know how it goes. Thanks
post Feb 9, 2007 - 11:57 AM
celicamike
Joined Dec 26, '05
From So Cal
So I tried that Pennzoil synchromesh oil in my tranny and to my surprise, the problem is gone. Thanks for the easy fix. I was always told that pennzoil is crap, at least their motor oil, but as for their synchromesh transmission fluid, it's a winner. I would recommend it to anyone.
post Feb 9, 2007 - 2:58 PM
jcbass7
Joined Apr 20, '06
From Florida
Guess i should try that, my tranny is giving me issues.
post Feb 9, 2007 - 3:09 PM
Negative
Joined Apr 28, '04
From Houston, Texas
My tranny has really started acting up lately. It used sometimes be hard to put into first until I came to a dead stop. Now it's hard to get into any gear at all. It feels like I'm gonna break the stick or the plastic mount underneath. If the car is rolling it feels like it is hard to get in and then will just drop in. If I forget to put it in 1st before I stop rolling to a stop it feels really hard to get in but will go in. Someone told me I need to change out a plastic bushing at the tranny where the linkage goes and that it is due to slamming into gear when racing.
Any ideas?
post Feb 9, 2007 - 3:13 PM
QUOTE(celicamike @ Feb 9, 2007 - 11:57 AM) [snapback]525418[/snapback]
syncromesh saves the day again ! its really great stuff.
Lo-Fi Version Time is now: June 10th, 2026 - 12:02 AM
