> OH CRAP!!!! SOMETHING BROKE!!!!!&#
post Jan 24, 2007 - 12:57 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I was driving on the highway about 70 mph today, I gave it a full boost accelleration and my friend in the pass seat noticed the shifter popped out of 5th gear into neutral. So I put it back into 5th and I couldnt accelerate. Now the car is stuck in 5th gear. All the shifter cables are good. I think the spec stage 2 disc broke. It was custom for the 3s swap using the stock gt transmission. Ive been hearing a rattle sound when at idle with the clutch petal out. When I pushed it in it would go away. I was told by spec that its my throw out bearing. It made sense at the time. I guess they were probably wrong. This sucks!!!!!I'll let you all know when I get it apart. later
-toyotacrazy
- toyotacrazy   OH CRAP!!!! SOMETHING BROKE!!!!!&#   Jan 24, 2007 - 12:57 PM
- - rzanology   damn.....hope it didnt damage anything too bad...   Jan 24, 2007 - 1:31 PM
- - x_itchy_b_x   haha oh man thats really familiar. happened to me...   Jan 24, 2007 - 1:38 PM
- - 6strngs   damn... I have a spec stage 2... if this happens t...   Jan 24, 2007 - 2:17 PM
- - toyotacrazy   will the v-6 solara 5 speed trans bolt right up to...   Jan 24, 2007 - 2:32 PM
- - playr158   yup its an E153 tranny   Jan 24, 2007 - 2:34 PM
- - celica3sgte   The v-6 solara tranny will slap right on. You nee...   Jan 24, 2007 - 2:42 PM
|- - toyotacrazy   QUOTE(celica3sgte @ Jan 24, 2007 - 2...   Jan 24, 2007 - 4:05 PM
- - toyotacrazy   thanks for the advise. when I was stranded I had ...   Jan 24, 2007 - 2:50 PM
- - celica3sgte   You can use a few things as a spacer. I used a ch...   Jan 24, 2007 - 4:17 PM
- - lagos   QUOTEIve been hearing a rattle sound when at idle ...   Jan 24, 2007 - 4:57 PM
- - malecrod   Sorry man, but it sounds all too familiar. I went ...   Jan 24, 2007 - 5:47 PM
- - toyotacrazy   Ok. I got it apart in 1 hour and 15 minutes on th...   Jan 24, 2007 - 10:04 PM
- - lagos   did you check your hydraulic lines?   Jan 24, 2007 - 10:08 PM
- - toyotacrazy   The clutch petal felt good and was moving normally...   Jan 24, 2007 - 10:17 PM
- - cheeco   just out of curiousity, does the spec stage 2 clut...   Jan 25, 2007 - 12:49 AM
|- - 6strngs   QUOTE(cheeco @ Jan 24, 2007 - 9:49 P...   Jan 25, 2007 - 12:59 AM
- - toyotacrazy   Yes mine has rivots. They look pretty sturdy thou...   Jan 25, 2007 - 6:33 AM
|- - cheeco   QUOTE(toyotacrazy @ Jan 25, 2007 - 6...   Jan 25, 2007 - 6:57 PM
- - x_itchy_b_x   New Design ^ Old Design ^ its a solid piece now ...   Jan 25, 2007 - 8:04 AM
- - jcbass7   Thats my stage two.. old design? i bought it last...   Jan 25, 2007 - 9:59 AM
- - toyotacrazy   That looks like the old design. Id contact spec b...   Jan 25, 2007 - 10:36 AM
|- - jcbass7   QUOTE(toyotacrazy @ Jan 25, 2007 - 10...   Jan 25, 2007 - 2:09 PM
- - toyotacrazy   So if I use a mr2 3sgte transmission, What do I n...   Jan 25, 2007 - 1:09 PM
|- - Silver94CelicaOwner   QUOTE(toyotacrazy @ Jan 25, 2007 - 11...   Jan 26, 2007 - 4:00 PM
- - toyotacrazy   5th gear slid off the shaft and was cutting into t...   Jan 26, 2007 - 1:49 PM
- - toyotacrazy   Thank you so much. Thats what I needed to know. ...   Jan 26, 2007 - 6:24 PM
- - presure2   QUOTEThe s534 broke the day after I raised my boos...   Jan 26, 2007 - 6:42 PM
- - lagos   QUOTEThe s534 broke the day after I raised my boos...   Jan 26, 2007 - 7:01 PM
- - toyotacrazy   Heres how it broke. I was on the highway doing ab...   Jan 26, 2007 - 9:54 PM
- - x_itchy_b_x   QUOTE(presure2 @ Jan 26, 2007 - 8:42...   Jan 26, 2007 - 10:01 PM
- - lagos   did you look inside to verify that the 5th gear sy...   Jan 26, 2007 - 10:34 PM
- - toyotacrazy   I took the box completely apart. I will take pic...   Jan 26, 2007 - 11:07 PM
Lo-Fi Version Time is now: August 2nd, 2026 - 10:10 AM
