Jan 31, 2007 - 8:31 PM
Enthusiast ![]() ![]() Joined Jan 22, '06 From Savannah, GA Currently Offline Reputation: 1 (100%) |
Almost brand new bought about a year and a half ago but only used for about a month with box from best buy (yuck) and soundstream amp.
the V-Max Cerwin Vega subs are rated at 600 watts apeice rms the at this address http://cerwin-vega.com/[/url] just go to mobile audio and then v-max 12". ill get pics asap The amp is a picasso series soundstream amp with these specs. • Fully regulated MOSFET power supplies • PWM circuitry • Tri-guard amplifier protection • IDIT (Intelligent Distress Indicator) gives a visual • indication of the amplifiers protection status • Line Outputs • Bi-linear selectable crossovers for inputs and utputs (Hi/Full/Low) • Continuously variable high and low-pass rossovers • Variable subwoofer equalizer • Phase inversion switch (0 - 180º) • OEM floating ground input • Platinum 4-gauge power connectors • Tri-mode operation the amp is a 300 dollar amp and it has literally only been used for about 2 weeks. i would like to get 400 for the set but make me an offer you mite be surprised |
Feb 1, 2007 - 11:43 PM
you know your all missn out right
| Lo-Fi Version | Time is now: August 29th, 2026 - 1:53 PM |
