> Tranny is dieing, advice?, threw a code (42) speed sensor
post Jan 31, 2007 - 10:11 PM
jcbass7
Joined Apr 20, '06
From Florida
UPDATE
This thread started as my speedometer issues thread. now its changed over to tranny issues in general. I think i need a new tranny.
Issues
-Seals leak even when brand new
-Speedo gear dead
-Rough Shifting
-Metallic noise when in neutral (goes away when i push in the clutch)
what do you all think???
Ok so it worked fine.. and then started working less.. (on and off) and now just doesn't work at all.. not one bit.. I thought maybe the plug was loose, but checked that and its fine..
where is the sensor in the tranny? maybe i need to check that end of the wiring..
any ideas? i'm tired of my mileage not getting logged...
This post has been edited by jcbass7: Feb 11, 2007 - 10:29 PM
- jcbass7   Tranny is dieing, advice?   Jan 31, 2007 - 10:11 PM
- - jcbass7   Bump any ideas how to fix the speedometer?   Feb 2, 2007 - 3:44 PM
- - Batman722   is it just the speedo or the entire gauge cluster ...   Feb 2, 2007 - 3:47 PM
- - jcbass7   JUST the speedo   Feb 3, 2007 - 6:13 PM
- - trdproven   the speedo is controlled by a speedometer gear, yo...   Feb 4, 2007 - 1:30 AM
- - celicast3sgte   i would check the sensor in the tranny first. loca...   Feb 4, 2007 - 4:10 AM
- - jcbass7   good stuff, I'll check that ASAP. I have two ...   Feb 4, 2007 - 11:23 AM
- - jcbass7   PS: the car has 210,000 on it an i think the trann...   Feb 4, 2007 - 11:36 AM
- - jcbass7   Ok so i think i need a new transmission... -sea...   Feb 8, 2007 - 1:38 PM
- - jcbass7   BUMP any ideas? I will be home tomorrow and will ...   Feb 9, 2007 - 2:59 PM
- - lagos   QUOTE(jcbass7 @ Feb 8, 2007 - 1:38 P...   Feb 9, 2007 - 3:09 PM
|- - jcbass7   QUOTE(lagos @ Feb 9, 2007 - 3:09 PM)...   Feb 9, 2007 - 3:26 PM
- - lagos   check that axle bracket. if that bracket is loose,...   Feb 9, 2007 - 3:30 PM
- - x_itchy_b_x   if i had an extra empty bay id say come over my ho...   Feb 9, 2007 - 3:34 PM
|- - jcbass7   QUOTE(x_itchy_b_x @ Feb 9, 2007 - 3...   Feb 9, 2007 - 6:22 PM
- - jcbass7   Ok so the car threw a code 42 today. in my book i...   Feb 11, 2007 - 5:12 PM
- - jcbass7   bump any advice on this code?   Feb 12, 2007 - 12:06 PM
- - x_itchy_b_x   check the sensor, and the wiring going to the ecu....   Feb 12, 2007 - 12:29 PM
- - jcbass7   Itchy, do you have the exploded pic of the axles? ...   Feb 12, 2007 - 1:21 PM
- - lagos   check to make sure that the speedo harness plug di...   Feb 12, 2007 - 3:30 PM
- - jcbass7   some more info: checked the bracket and its on th...   Feb 12, 2007 - 5:05 PM
Lo-Fi Version Time is now: August 9th, 2026 - 2:14 PM
