Feb 5, 2007 - 11:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
why am i making this thread? after seeing K-ESD's completed v6 swap, i started looking into it as an option. the v6 swap has been a popular swap in mk1 and mk2 mr2's for a while now. v6 swap information is relatively sparse for the celica community, and i want to help change that. seems to me that too many people here jump on the 3sgte bandwagon without really exploring their options. there is a reason that owners of mk2 mr2 turbos are swapping out there 3sgte in favor of a v6. a v6 (by nature of its increased displacement) will give more low rpm torque than a 3sgte will stock for stock, and such, it makes a great daily driver. with relatively moderate modifications, a v6 can be made to produce huge hp with a wide powerband. and the best part, these engine are a dime a dozen. use www.car-part.com to find them locally in salvage yards for cheap. now there are a lot of options for a swap: 3vzfe, 5vzfe, 1mzfe, 3mzfe being the most popular. i myself plan on doing this swap either summer 07 or summer 08. i will be updating this thread with lots of info ive gathered, and it will be regularly checked checked for accuracy and clarity.
purpose of this post is to generate interest in the v6 swap and to provide a one-stop place to compile general and 6gc-specific v6 swap information. Engine Information: 3VZ-FE: -3.0L -cast iron block -factory engine girdle -overbuilt internals -OBD 1 -return type fuel system -non interference -distributor ignition -engine hp/trq *185hp @ 5200rpm / 195ftlb @ 4400rpm -found in USDM *92-93 Toyota Camry *92-93 Lexus ES 300 1MZ-FE: -3.0L -aluminum alloy block -lightweight internals -OBD 2 -returnless fuel system 97+ -non interference for non-VVTi, interference for VVTi -COP ignition -multiport fuel injection -forged powdered metal fracture split connecting rod -drive by wire certain models/years -engine hp/trq (several revisions) *94-96: 188hp @ 5200rpm / 203ftlb @ 4400rpm *97+: 192hp @ 5300rpm / 209ftlb @ 4400rpm *97+ (solara specific): 200hp @ 5200rpm / 214lbft @ 4400rpm (gains from improved exhaust/intake plumbing) *99+ with VVTi: 210hp @ 5800rpm / 220ftlb @ 4400rpm -found in USDM *94-06 Toyota Camry *99-03 Toyota Solara *97-01 Lexus ES 300 *99-03 Lexus RX 300 *95-04 Toyota Avalon *98-03 Toyota Sienna -vehicles with VVTi 1mzfe *03-06 Toyota Camry *00-04 Toyota Avalon *01-03 Toyota Highlander *99-01 Lexus ES 300 *99-03 Lexus RX 300 *01-03 Toyota Sienna 3MZ-FE: -3.3L -aluminum alloy block -VVTi equipped -shares many components with 1MZ-FE -sequential fuel injection -forged steel connecting rod -drive by wire -engine hp/trq *225hp @ 5600rpm / 240ftlb @ 3600rpm -found in USDM *04-06 Toyota Camry SE V6 *04- Toyota Camry Solara *04-06 Toyota Sienna *03- Toyota Highlander *03-06 Lexus RX 330 *06- Lexus RX 400h *04-06 Lexus ES 330 Transmission Information: Manual Transmissions: S-54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: 3.944, 4.176 -3.944 diff found in JDM/UK 2nd and 3rd gen 3S-GE -4.176 diff found in MK2 MR2 NA and 6gc GT S-51: 3.538, 1.960, 1.250, 0.945, 0.731 / FD: 3.944 - found in I4 Camry E-153: 3.230, 1.913, 1.258, 0.918, 0.731 / FD: 3.933, 4.285 -3.933 diff found in V6 Camry -4.285 diff found in MK2 MR2 turbo -V6 E-153 upgraded from 2 to 3 synchros 93+ Automatic Transmissions: A-541E: A-140E: Swap Troubleshooting and Guides: to come Dynos and Engine Specifications: 3VZ-FE vs 1MZ-FE ![]() 94 1MZ-FE vs 97 1MZ-FE ![]() ![]() 97 1MZ-FE vs 99 1MZ-FE with VVTi ![]() VVTi 1MZ-FE vs 3MZ-FE ![]() ![]() V6 Discussion Forums: -mr2boards -mr2oc (membership required) 6gc V6 Swaps: -K-ESD with 3MZ-FE -1MZ-FE swap (pics only) Pictures 3VZ-FE vs Eagle 22R vs 1MZ-FE
This post has been edited by celicaST: Mar 1, 2007 - 8:03 AM -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
celicaST the v6 swap information thread Feb 5, 2007 - 11:14 PM
My2Celi I've researched a bit and I leaning toward the... Feb 5, 2007 - 11:35 PM
celicaST QUOTE(My2Celi @ Feb 5, 2007 - 9:35 P... Feb 5, 2007 - 11:41 PM
j0e_p3t man, forget my beams swap. i now want a 99+ 1mzfe. Feb 6, 2007 - 1:29 AM
Bigmeanbulldog55 Seems a no brainer to me to go with a 04+ 1mzfe. ... Feb 6, 2007 - 9:02 AM
Rayme QUOTE(Bigmeanbulldog55 @ Feb 6, 2007 - 1... Feb 6, 2007 - 10:52 AM
FORGMANN hmm .. a few notes ..
i highly reccommend getti... Feb 6, 2007 - 3:06 PM
jdg371 the V series engine is best for Forced Induction. ... Feb 6, 2007 - 3:27 PM
FORGMANN correction make that 3 .. and btw there is just e... Feb 6, 2007 - 3:37 PM
Batman722 QUOTE(FORGMANN @ Feb 6, 2007 - 3:37 ... Feb 7, 2007 - 2:43 AM
Chanh55 Nice write up. Feb 7, 2007 - 6:18 PM
snapshotgt I think we need another teaser pic bwahahaha Apr 23, 2007 - 4:42 PM
azian_advanced ^nice. Feb 7, 2007 - 2:33 AM
j0e_p3t more pics! Feb 7, 2007 - 2:48 AM
FORGMANN here is y pipe .. you have to run something simila... Feb 8, 2007 - 1:32 PM
laff09 isnt 13 an unlucky number? Feb 9, 2007 - 2:30 PM
celicaST new and revised info added Mar 1, 2007 - 7:48 AM
j0e_p3t bump Apr 8, 2007 - 2:37 PM
Punch nice you should do one on boost , there a afew so... Apr 8, 2007 - 3:04 PM
snapshotgt QUOTE(Punch @ Apr 8, 2007 - 3:04 PM)... Apr 10, 2007 - 4:12 PM
Kwanza26 If it were me doing this swap... 1/3MZ or nothing.... Apr 10, 2007 - 3:08 PM
celicaST QUOTE(Kwanza26 @ Apr 10, 2007 - 2:08... Apr 11, 2007 - 2:48 AM
Kwanza26 QUOTE(celicaST @ Apr 11, 2007 - 7:48... Apr 11, 2007 - 10:11 AM
stephen_lee I'm planning on swapping in a 5VZ-FE into my 9... Apr 10, 2007 - 4:55 PM
FORGMANN the one issue you may have is the height of motor ... Apr 10, 2007 - 7:35 PM
stephen_lee Hmm, okay. i was leaning towards the 3MZ at first,... Apr 10, 2007 - 9:42 PM
My2Celi How did you fabricate your adapter plate? Will it ... Apr 10, 2007 - 10:59 PM
Celicaguy13 Awesome! more v6 celicas. I'm planning to ... Apr 10, 2007 - 11:44 PM
FORGMANN guys i will tell you the absolute best set up is a... Apr 11, 2007 - 4:29 PM
celicaST QUOTE(FORGMANN @ Apr 11, 2007 - 3:29... Apr 12, 2007 - 2:48 AM
FORGMANN btw
here is a 4g swap .. overall most info can ... Apr 11, 2007 - 4:33 PM
FORGMANN yes and no ..
96-98 would be "better" ... Apr 12, 2007 - 10:28 AM
stephen_lee Well, i've decided on the 3VZ-FE. Does anyone ... Apr 23, 2007 - 2:50 PM
Jeremiah Okay, as a newb and as someone that lives in the N... Apr 23, 2007 - 7:40 PM
Celicaguy13 wow due your getting your info from an old site...... Apr 25, 2007 - 8:58 PM
j0e_p3t ^ so that's all i have to do after the swap is... Apr 30, 2007 - 10:21 PM
Jeremiah Can anyone tell me which V6's had the sludge p... May 1, 2007 - 6:26 PM
celicaST QUOTE(Jeremiah @ May 1, 2007 - 5:26 ... May 5, 2007 - 2:10 AM
stephen_lee im not sure which engines had the problem, but its... May 3, 2007 - 11:52 PM
My2Celi Well it doesn't matter just get either a 3vz, ... May 4, 2007 - 12:00 AM
Celicaguy13 QUOTE(j0e_p3t @ Apr 30, 2007 - 10:21... May 4, 2007 - 10:47 AM
Kwanza26 QUOTE(Celicaguy13 @ May 4, 2007 - 3... May 7, 2007 - 10:01 PM
j0e_p3t but obd2 should be no prob right? i'm planning... May 5, 2007 - 1:55 AM
Celicaguy13 QUOTE(j0e_p3t @ May 5, 2007 - 1:55 A... May 5, 2007 - 7:40 PM
j0e_p3t QUOTE(Celicaguy13 @ May 5, 2007 - 5... May 8, 2007 - 2:04 AM
undasighted QUOTE(FORGMANN @ Feb 6, 2007 - 8:37 ... May 6, 2007 - 11:37 AM
CelicaST_CALI Ok im also in cali and u say that all of the engin... May 6, 2007 - 1:01 PM
Celicaguy13 I don't know how to actually import the car. H... May 8, 2007 - 3:53 AM
Celicaguy13 QUOTE(Kwanza26 @ May 7, 2007 - 10:01... May 8, 2007 - 3:57 AM
Jeremiah Look - Hit up the DMV web site, or go to the DMV f... May 9, 2007 - 2:55 PM
Celicaguy13 QUOTE(Jeremiah @ May 9, 2007 - 2:55 ... May 9, 2007 - 3:54 PM
Kwanza26 QUOTE(Celicaguy13 @ May 9, 2007 - 8... May 9, 2007 - 8:48 PM
Jeremiah QUOTE(Celicaguy13 @ May 9, 2007 - 3... May 10, 2007 - 12:47 AM
celicaST QUOTE(Jeremiah @ May 9, 2007 - 1:55 ... May 10, 2007 - 12:57 AM
Jeremiah QUOTE(celicaST @ May 10, 2007 - 12:5... May 10, 2007 - 5:27 AM
CelicaST_CALI lol amen to the mocking of the auto!!... May 9, 2007 - 5:24 PM
FORGMANN if you guys noticed that 1mz swap done in Uk was a... May 10, 2007 - 11:23 AM
Eds94GT I found the engine I want in by 6gc!!... May 27, 2007 - 9:24 AM
snapshotgt Teaser video May 30, 2007 - 11:57 AM
stephen_lee I'm definitely going with the 3VZ-FE, for a fe... May 31, 2007 - 1:09 AM
stephen_lee Quoted $7500 from the Doc.
a little more than... Jun 3, 2007 - 2:48 PM
My2Celi My input would be
You need:
Motor: 3vzfe, 4vzfe, ... Jun 4, 2007 - 12:25 AM
stephen_lee QUOTE(My2Celi @ Jun 4, 2007 - 5:25 A... Jun 4, 2007 - 12:29 AM
praetor QUOTE(stephen_lee @ Jun 4, 2007 - 3... Aug 4, 2007 - 10:08 PM
My2Celi yup. Who else on here is doing the swap or plannin... Jun 4, 2007 - 12:03 PM
stephen_lee i really think the swaps are worth it.
yes 4cyl a... Jun 4, 2007 - 12:09 PM
Jeremiah As long as the total cost of the project is under ... Jun 7, 2007 - 5:17 PM
6strngs So, if you got a 1mzfe from a 94-97camry, it'l... Aug 12, 2008 - 1:47 AM
Legit94GT So buying the v6 is way cheaper than doing a 3s...... Aug 12, 2008 - 7:48 PM
3SGTE-auto I have a Celica and it was a 2.2L Automatic when I... Sep 13, 2008 - 5:49 PM
palooke QUOTE (3SGTE-auto @ Sep 13, 2008 - ... Sep 17, 2008 - 1:32 PM
3SGTE-auto Dear Palooke,
I thought people on this forum migh... Sep 17, 2008 - 11:39 PM
palooke QUOTE (3SGTE-auto @ Sep 17, 2008 - ... Sep 18, 2008 - 5:06 PM
Yes, I could start a thread on moun... Sep 18, 2008 - 10:19 PM
BonzaiCelica is this not stickied? Oct 6, 2013 - 2:04 PM
Smaay lots of mis information in this thread. I dont thi... Oct 6, 2013 - 5:47 PM
fatherof4 QUOTE (Smaay @ Oct 6, 2013 - 6:47 PM... Oct 6, 2013 - 10:33 PM
kevin311 I agree with Smaay. Just from what I've learne... Oct 8, 2013 - 8:55 AM
Smaay i think im going to do it in parts.
Part I engi... Oct 9, 2013 - 5:35 PM
CAcelica29 QUOTE (Smaay @ Oct 9, 2013 - 5:35 PM... Dec 14, 2013 - 4:11 PM
njccmd2002 Part 1 is done..... Dec 14, 2013 - 4:39 PM
CAcelica29 ^^^im aware, just really want to know when abouts ... Dec 15, 2013 - 3:51 AM
ILoveMySilly97 QUOTE (CAcelica29 @ Dec 15, 2013 - 12... Jan 1, 2014 - 2:00 PM
Smaay read my V6 thread for more info. Its going to be a... Dec 15, 2013 - 3:46 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:26 PM |
