Feb 12, 2007 - 10:55 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
I took this 94 GT for a test drive a week ago and only reason i didnt buy it was that it made this really weird grinding noise.. almost sounds like when you drag something over concrete buti couldnt find anything on the underside hanging or notice anything that stood out with the suspension and the tires seemed fine.. anyone have any idea what it coulda been?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
Feb 12, 2007 - 11:48 AM
all the time or just when the brakes are applied?
Feb 12, 2007 - 12:26 PM
Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
Might be a wheel bearing. I had one go bad and it sounded kind of like that.
Feb 12, 2007 - 12:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I had a noise like that when my engine mount bolt fell out.. so the right side of the engine was sagging.. so it put pressure on the axle..
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Feb 12, 2007 - 4:44 PM
Only in movement, not when braking and wouldnt a bearing noise make a whinning noise? Actually thinking back the brakes did sink right in when you pressed em so maybe the pads were binding up on the caliper and just dragging really badly....
Feb 12, 2007 - 5:11 PM
QUOTE(FreddyTheOthaMeat @ Feb 12, 2007 - 3:44 PM) [snapback]526233[/snapback] Only in movement, not when braking and wouldnt a bearing noise make a whinning noise? Actually thinking back the brakes did sink right in when you pressed em so maybe the pads were binding up on the caliper and just dragging really badly.... No, it usually sounds like a grinding noise from the wheel that varies with speed. Sometimes like a very very rapid clicking. |
Feb 12, 2007 - 10:16 PM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
QUOTE(94GT @ Feb 12, 2007 - 5:11 PM) [snapback]526245[/snapback] QUOTE(FreddyTheOthaMeat @ Feb 12, 2007 - 3:44 PM) [snapback]526233[/snapback] Only in movement, not when braking and wouldnt a bearing noise make a whinning noise? Actually thinking back the brakes did sink right in when you pressed em so maybe the pads were binding up on the caliper and just dragging really badly.... No, it usually sounds like a grinding noise from the wheel that varies with speed. Sometimes like a very very rapid clicking. I've had front wheel bearings go bad enough times for me to completely agree with you there. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
| Lo-Fi Version | Time is now: September 15th, 2026 - 5:10 AM |
