> piston help
post Feb 12, 2007 - 3:53 PM
trd94
Joined Jan 9, '05
From green springs ohio
ok i have read that the 4age head gasket fits a 7afe so i would like to know if i use a set of 4agze pistons with a 2mm head gasket will i be ok for 10-12psi of boost or will the gze pistons raise the compression to much even with the 2mm steel gasket smile.gif just need some input befor i buy parts i dont need biggrin.gif thanks guys
- trd94   piston help   Feb 12, 2007 - 3:53 PM
- - playr158   you arn't a newbie stickie http://www.6gc.ne...   Feb 12, 2007 - 4:44 PM
- - trd94   yeah i searched and read what you wrote about the ...   Feb 12, 2007 - 5:06 PM
- - playr158   2mm is the max you really want to go... the best s...   Feb 12, 2007 - 5:17 PM
- - trd94   this is true ,and if i would use the 10:XX:1 ratio...   Feb 12, 2007 - 10:50 PM
- - playr158   with the higher compression ratio, you would gain ...   Feb 12, 2007 - 11:01 PM
- - lagos   raising compression and adding boost is a bad idea...   Feb 12, 2007 - 11:05 PM
|- - trd94   QUOTE(lagos @ Feb 12, 2007 - 11:05 P...   Feb 12, 2007 - 11:11 PM
- - playr158   how is runing a low 10.x:1 or high 9.X:1 compressi...   Feb 12, 2007 - 11:08 PM
- - playr158   well not just the headgasket you would be able to ...   Feb 12, 2007 - 11:13 PM
|- - trd94   QUOTE(playr158 @ Feb 12, 2007 - 11:1...   Feb 12, 2007 - 11:19 PM
- - lagos   QUOTE(playr158 @ Feb 12, 2007 - 11:0...   Feb 12, 2007 - 11:31 PM
|- - trd94   QUOTE(lagos @ Feb 12, 2007 - 11:31 P...   Feb 12, 2007 - 11:44 PM
- - playr158   lagos you do realize stock compression is like 9.5...   Feb 12, 2007 - 11:45 PM
|- - trd94   QUOTE(playr158 @ Feb 12, 2007 - 11:4...   Feb 12, 2007 - 11:53 PM
|- - presure2   QUOTE(playr158 @ Feb 12, 2007 - 11:4...   Feb 13, 2007 - 6:20 AM
- - lagos   can you post your dyno sheets? that way, we would ...   Feb 13, 2007 - 12:30 AM
- - playr158   probably in the head? lol i think thats an underst...   Feb 13, 2007 - 12:44 AM
- - lagos   QUOTE(playr158 @ Feb 13, 2007 - 12:4...   Feb 13, 2007 - 12:51 AM
- - playr158   because 7afe pistons are right about even with the...   Feb 13, 2007 - 12:58 AM
- - lagos   QUOTEbecause 7afe pistons are right about even wit...   Feb 13, 2007 - 1:05 AM
- - playr158   QUOTE(presure2 @ Feb 13, 2007 - 6:20...   Feb 13, 2007 - 9:22 AM
- - trd94   ok here is my plan, i am putting in a new timing b...   Feb 13, 2007 - 11:00 AM
- - Punisher   Ya know.. maybe some people just like being ...   Feb 13, 2007 - 11:11 AM
|- - trd94   QUOTE(Punisher @ Feb 13, 2007 - 11:1...   Feb 13, 2007 - 11:28 AM
- - playr158   haha i like this guy!   Feb 13, 2007 - 12:04 PM
|- - Punisher   QUOTE(playr158 @ Feb 13, 2007 - 12:0...   Feb 13, 2007 - 1:48 PM
|- - trd94   QUOTE(Punisher @ Feb 13, 2007 - 1:48...   Feb 13, 2007 - 3:09 PM
- - lagos   QUOTEyeah i could do a swap and then whin i go to ...   Feb 13, 2007 - 3:53 PM
|- - trd94   QUOTE(lagos @ Feb 13, 2007 - 3:53 PM...   Feb 13, 2007 - 4:14 PM
|- - playr158   QUOTE(lagos @ Feb 13, 2007 - 3:53 PM...   Feb 13, 2007 - 9:28 PM
- - trd94   hey player who is running the 11:1 setup could you...   Feb 13, 2007 - 10:05 PM
|- - Punisher   Um.. So you're saying that if you swapped a 5t...   Feb 14, 2007 - 12:08 AM
- - trd94   a legal motor swap would be a motor from that mode...   Feb 14, 2007 - 8:39 AM
- - jason   QUOTE besides.. a 3S is a bolt in swap on an st? ...   Feb 16, 2007 - 10:38 PM
|- - Punisher   QUOTE(jason @ Feb 16, 2007 - 10:38 P...   Feb 16, 2007 - 11:58 PM
- - playr158   mounts don't just bolt in...you have to drill ...   Feb 17, 2007 - 2:36 PM
|- - Punisher   QUOTE(playr158 @ Feb 17, 2007 - 2:36...   Feb 19, 2007 - 2:19 AM
- - playr158   honestly the 3s isn't the holy **** of motors ...   Feb 19, 2007 - 11:22 AM
- - Negative   LOL. He wants more form his 7A - it's his moto...   Feb 19, 2007 - 11:35 AM
|- - trd94   QUOTE(Negative @ Feb 19, 2007 - 11:3...   Feb 19, 2007 - 3:33 PM
- - frotou   Trd ; the most important thing you must specify wi...   Feb 19, 2007 - 6:45 PM
|- - trd94   QUOTE(frotou @ Feb 19, 2007 - 6:45 P...   Feb 20, 2007 - 5:03 PM
|- - Negative   QUOTE(trd94 @ Feb 20, 2007 - 10:03 P...   Feb 21, 2007 - 12:30 PM
- - Punisher   I don't care what he does it's up to him.....   Feb 19, 2007 - 9:51 PM
- - playr158   QUOTE(Punisher @ Feb 19, 2007 - 9:51...   Feb 20, 2007 - 9:14 AM
- - frotou   Hum... I think you'll get too high CR with 4a ...   Feb 21, 2007 - 9:23 AM
- - playr158   QUOTE(frotou @ Feb 21, 2007 - 9:23 A...   Feb 21, 2007 - 3:11 PM
- - trd94   do you think with a 2mm head gasket it would get i...   Feb 21, 2007 - 4:05 PM
- - playr158   you'd have to use an engine calculator (searc...   Feb 21, 2007 - 4:07 PM
Lo-Fi Version Time is now: June 12th, 2026 - 11:32 AM
