> Progressive Rubbing Noise?, After installing suspension...
post Feb 20, 2007 - 11:10 AM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Hey all,
I just did my front suspension (TRD Springs, KYB GR-2s, and ST Sways) and now as I'm driving theres a rubbing sound but it only appears to happen as the cars moving and is progressive with speed. Sometimes it's really loud and vibrates the car and sometimes it's not, but still there. It's with wheel rotation so it leads me to believe that it's something with the wheel? Could it be a freak wheel bearing that went out right after I did my suspension? It's on the front passenger side I think, unless it's the rear passenger side and it sounds like the front?
Thanks in advance.
This post has been edited by GTS13: Feb 20, 2007 - 1:13 PM
post Feb 20, 2007 - 5:12 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Alright folks. I've done a lot of research and sadly my particular situation points to a lot of things, but since it's soooo damn loud now and vibrates a lot...my guess is now that I have a bad bearing in either the front or rear passenger, my guess is rear since the situation has added more noises back there at lower speeds. Although that could just be because the vibrations fecked some stuff up back there. Anyway, I'm off to the mechanic in two hours for an assessment and I'll keep you all posted along with a more detailed description of the problem for reference to those who might need it later.
post Feb 21, 2007 - 1:11 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Ok so just to finish this off...I had loose lugnuts thanks to my own forgetfulness. Luckily no serious damage was done and we did the rear suspension last night. The car drives amazing!
This post has been edited by GTS13: Feb 21, 2007 - 1:11 PM
Lo-Fi Version Time is now: August 1st, 2026 - 9:02 AM
