> Help Cusco OS Strut Bars, Fitment Question
post Feb 27, 2007 - 1:19 AM
TRD-ST204
Joined Sep 26, '04
From Sacramento, California
Does Cusco make an OS type strut bar for the GT-Four and FF drivetrain Celicas? I believe that they do and the difference between the FF strut bar and the GT-Four one is that the middle of the bar on the GT-Four version is slightly raised to compensate for the throttle body or intercooler, right? So here is what I'm thinking, GT-Four has a slightly raised hood to compensate for the raise in the strut bar, so would that strut bar fit on a non-GT-Four Celica with a stock hood with out vents? The other side of my thinking is that there is only one bar and it fits both GT-Four and FF Celicas. The reason why I'm asking all of these questions is because I want to buy a Cusco OS strut bar that is made for a GT-Four and install in my ST204. I want to know if the my stock hood clears the strut bar. Sorry, I was so elaborative, please answer any of the question above if possible, thanks.
post Feb 27, 2007 - 1:32 AM
celicaST
Joined Jun 23, '05
im not sure if they are taller for the st205, just buy the one for the ff so you dont have to worry http://japanparts.com/db/partslist.php?dea...=3&small=15
edit- they have different part numbers, guessing they arent the same
This post has been edited by celicaST: Feb 27, 2007 - 1:34 AM
post Feb 27, 2007 - 1:34 AM
TRD-ST204
Joined Sep 26, '04
So what you're trying to say is that Cusco makes one for the GT-Four and one for the FF Celicas, right?
QUOTE(celicaST @ Feb 27, 2007 - 6:32 AM) [snapback]530742[/snapback]
post Feb 27, 2007 - 1:36 AM
celicaST
Joined Jun 23, '05
QUOTE(TRD-ST204 @ Feb 26, 2007 - 11:34 PM) [snapback]530745[/snapback]
see my edit above. since they have different part numbers, thats what i would guess.
post Feb 27, 2007 - 2:44 AM
TRD-ST204
Joined Sep 26, '04
But, all the part numbers on that website are different including the parts that are the same. For example,Cusco only makes one OS type rear strut bar for the 6gc and Japanparts has two different number for the ST205 and ST202/ST203.
post Feb 27, 2007 - 9:13 AM
fanboy95
Joined Feb 26, '06
From Illinois
yes the strut tower bar os is raised in the middle for a 204. my st hood rubs it a tiny bit but it still fits.
This post has been edited by fanboy95: Feb 27, 2007 - 9:13 AM
post Feb 27, 2007 - 9:52 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i have an Apex'i strut bar (very similar to Cusco) and is made for the ST205. back when i still had my oem hood, it used to rub and you'd kinda have to push hard to lock the hood. and the foam insulator of the hood left black stains on my strut bar due to the heat in the engine bay, but can be cleaned off easily.
This post has been edited by azian_advanced: Feb 27, 2007 - 9:54 AM
post Feb 28, 2007 - 12:57 AM
TRD-ST204
Joined Sep 26, '04
Thanks, that helps a lot!
QUOTE(azian_advanced @ Feb 27, 2007 - 2:52 PM) [snapback]530824[/snapback]
What's is the part number on your OS bar? Is it 153-540 A?
QUOTE(fanboy95 @ Feb 27, 2007 - 2:13 PM) [snapback]530811[/snapback]
This post has been edited by TRD-ST204: Feb 28, 2007 - 12:56 AM
Lo-Fi Version Time is now: August 27th, 2026 - 1:03 AM
