> just ordered a nitrous kit!!
post Feb 27, 2007 - 4:49 PM
nate95
Joined May 5, '05
From mattoon, IL
well i just ordered a dry shot nitrous kit, the kit comes with several different sized jets from a 10shot up to 100shot, so im prolly just going to be running like a 25-30shot to keep it safer. as soon as the kit comes in i'll get it installed and post some pics up! im really curious as to the results i will get.
- nate95   just ordered a nitrous kit!!   Feb 27, 2007 - 4:49 PM
- - hashmaster52   nice! how much was it??? if u could, post a vi...   Feb 27, 2007 - 4:54 PM
- - shin   so you're going boost + nos ???   Feb 27, 2007 - 5:11 PM
- - presure2   dry kits are tough, man....be carefull how big a j...   Feb 27, 2007 - 5:35 PM
|- - Rockford   QUOTE(presure2 @ Feb 27, 2007 - 6:35...   Feb 27, 2007 - 6:54 PM
- - nate95   im going to be running really small jets from a 10...   Feb 28, 2007 - 9:54 AM
- - NuclearHappineS   i could tell you what size injectors to get, but t...   Mar 1, 2007 - 10:11 AM
- - nate95   so why wont a larger fuel pump, FPR, and larger in...   Mar 1, 2007 - 1:25 PM
|- - celicaST   QUOTE(nate95 @ Mar 1, 2007 - 11:25 A...   Mar 1, 2007 - 2:28 PM
- - nate95   well the fpr is adjustable, so when i dont use the...   Mar 1, 2007 - 2:59 PM
- - Negative   No he means even while you are running with it set...   Mar 1, 2007 - 3:37 PM
|- - celicaST   QUOTE(Negative @ Mar 1, 2007 - 1:37 ...   Mar 1, 2007 - 3:42 PM
- - Negative   Much better put. that's what I was trying to s...   Mar 1, 2007 - 4:11 PM
- - nate95   is there a way i can convert my dry kit to a wet k...   Mar 1, 2007 - 4:44 PM
- - lagos   remember when i tried to tell you NOT to get a dry...   Mar 1, 2007 - 5:28 PM
- - nate95   they make a conversion kit for it so im ok bu...   Mar 1, 2007 - 5:32 PM
- - NuclearHappineS   you can't make your own Tee unless you know al...   Mar 1, 2007 - 6:25 PM
- - NuclearHappineS   here is the info at your own risk ...and with a co...   Mar 1, 2007 - 6:48 PM
- - nate95   hey thanks alot for that info,, i do think it woul...   Mar 1, 2007 - 7:42 PM
- - NuclearHappineS   did you already buy it, you don't need it   Mar 2, 2007 - 4:41 AM
- - nate95   ya i already bought it.. i dont need it for a wet ...   Mar 2, 2007 - 1:03 PM
- - nate95   well i got the nitrous kit installed and i have to...   Mar 9, 2007 - 3:38 AM
Lo-Fi Version Time is now: June 11th, 2026 - 7:10 PM
