> best way to fix a broken highbeam tab
post Mar 1, 2007 - 12:27 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
I'm tired of one of my highbeams boucing up and down, the broken part of the tab is still bolted down, and fits perfect when you push them toghether.
so is their a glue strong enought to glue it back together or will it just separate again as soon as i drive?
Replies (1 - 7)
post Mar 1, 2007 - 12:46 PM
DSToyo
Joined Dec 16, '06
From Maryland
what i did (dont know if its the best way) is got some fiberglass cloth, and some stuff called Liquid Nails (small projects tube) and kind of mixed a bunch of that with some cloth and attached the tab back on after sanding both ends. it takes a while to dry, but it has worked great so far. the good thing about it is that you cant see the liquid nails stuff cause the bumper goes over the tabs. anyway, thats just one way smile.gif
post Mar 1, 2007 - 1:02 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
intereseting i think i will try that
post Mar 1, 2007 - 1:39 PM
or some JB Weld will work fine too.
post Mar 1, 2007 - 8:34 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
use model(like model car) glue. the stuff actually melts the plastic together making more than a seal, but a piece in union again.
post Mar 5, 2007 - 11:44 AM
6gcelikas
Joined Oct 30, '05
From MICHIGAN
QUOTE(illneversellmycelli @ Mar 1, 2007 - 12:27 PM) [snapback]531717[/snapback]
Best way to fix boken tabs is to use soldering gun and melt both plastics, but you have to do thid in stages.
Below is the link to headlamps that I fixed.
http://i122.photobucket.com/albums/o271/6g...eadlamps007.jpg
http://i122.photobucket.com/albums/o271/6g...eadlamps006.jpg
http://i122.photobucket.com/albums/o271/6g...eadlamps004.jpg
http://i122.photobucket.com/albums/o271/6g...eadlamps002.jpg
post Mar 6, 2007 - 2:33 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
GORILLA GLUE!
RAWWWWWWWWWWR
post Mar 8, 2007 - 8:22 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
thx for you guys for the tips, for one tab sanding down and uses some model glue worked great, the other tab, glue wouldnt cut it, so i used my soldering iron as a heat gun and melted them togheher like the one guy said, worked perfect, thank you guys
Lo-Fi Version Time is now: September 1st, 2026 - 6:35 AM
