Mar 8, 2007 - 11:50 PM
What do you guys run for daily driven PSI? I was looking at alot of the dyno sheets and ppl were posting they were runnin at 16, 17 psi..and i know you crank the boost up to get ur max power..but whats a safe daily driven pressure to be running at?
Mar 8, 2007 - 11:53 PM
Enthusiast ![]() Joined Jan 6, '06 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
With a stock 2nd gen 3sgte I wouldnt crank it up more than 15 psi.
Mar 9, 2007 - 12:25 AM
im at 16psi daily, but for most stockish jdm 3sgte's i wouldnt crank it up past 13-14psi, unless you have a way to monitor knock or EGTs.
Mar 9, 2007 - 3:54 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
im at 10 psi with a 2nd gen jdm ecu.
Mar 9, 2007 - 6:33 AM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
Im at 10 psi. But Im thirsty for more!
Mar 9, 2007 - 10:27 AM
QUOTE(6gsillyca @ Mar 9, 2007 - 2:54 AM) [snapback]534596[/snapback] im at 10 psi with a 2nd gen jdm ecu. Your 10psi is not like other people's 10psi -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 9, 2007 - 10:33 AM
ct26 i ran 18 daily after the new fmic. before than i ran 15.
with the holset i plan to run 18psi daily. -------------------- |
Mar 9, 2007 - 12:51 PM
QUOTE(jgreening @ Mar 9, 2007 - 8:27 AM) [snapback]534656[/snapback] QUOTE(6gsillyca @ Mar 9, 2007 - 2:54 AM) [snapback]534596[/snapback] im at 10 psi with a 2nd gen jdm ecu. Your 10psi is not like other people's 10psi Haha I never said it was...he just asked for DD psi... |
Mar 11, 2007 - 4:01 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
ive been running around lately on 15-16psi but i like to keep it at 10psi when im going to work.
| Lo-Fi Version | Time is now: July 29th, 2026 - 1:32 AM |
