Mar 9, 2007 - 7:21 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
I'm wanting to put a shift light in my car, but I'm not exactly sure what to go for. Stock tach is great for me. In fact, I have a big preference for making things look as stock as possible. What I am thinking about is someone just hooking up a couple LEDs infront of the steering wheel so they are easily seen by me but not others. Anyone know anything about this DIY shift light stuff? Seems like I could tap into something that would send a signal at a certain rpm without paying $50 for it.
Mar 9, 2007 - 8:32 AM
id jsut buy a cheap ebay one and take it apart to place the leds where ever.
http://cgi.ebay.com/ebaymotors/RPM-SHIFT-L...093155726QQrdZ1 -------------------- |
Mar 9, 2007 - 11:27 PM
QUOTE(x_itchy_b_x @ Mar 9, 2007 - 8:32 AM) [snapback]534627[/snapback] id jsut buy a cheap ebay one and take it apart to place the leds where ever. http://cgi.ebay.com/ebaymotors/RPM-SHIFT-L...093155726QQrdZ1 that's actually a pretty good idea...and wouldn't be that difficult to do... -------------------- |
Mar 11, 2007 - 5:53 PM
QUOTE(x_itchy_b_x @ Mar 9, 2007 - 8:32 AM) [snapback]534627[/snapback] id jsut buy a cheap ebay one and take it apart to place the leds where ever. http://cgi.ebay.com/ebaymotors/RPM-SHIFT-L...093155726QQrdZ1 I didn't see any that cheap before. As long as it's acturate, it will work. What I would like is to make a device to tell me what gear the car is in, and that's pretty easy to set up. And also have a top limit and bottem limit. That way, while racing I could keep the car right wear it needs to be. -------------------- Live Free, Be Happy
Mar 11, 2007 - 6:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
QUOTE What I would like is to make a device to tell me what gear the car is in, and that's pretty easy to set up. And also have a top limit and bottem limit. thats a very good idea!! i was working a little while back with making a device to tell which gear the car was in and also tell when in nuetral, wasnt a big priority of mine and i eventually gave up, but id deff want the same setup as you with the tach stuff - like a green led when rpm's too low, and a red one when they are too high, stick em off to the left next to where the factory fog light button would go =) -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Mar 11, 2007 - 7:57 PM
QUOTE(jason @ Mar 11, 2007 - 6:01 PM) [snapback]535311[/snapback] QUOTE What I would like is to make a device to tell me what gear the car is in, and that's pretty easy to set up. And also have a top limit and bottem limit. thats a very good idea!! i was working a little while back with making a device to tell which gear the car was in and also tell when in nuetral, wasnt a big priority of mine and i eventually gave up, but id deff want the same setup as you with the tach stuff - like a green led when rpm's too low, and a red one when they are too high, stick em off to the left next to where the factory fog light button would go =) I want to put it right behind the steering wheel on a flat looking piece. It would read /\ R 1 2 3 4 5 \/. -------------------- Live Free, Be Happy
Mar 11, 2007 - 9:35 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
QUOTE(Bigmeanbulldog55 @ Mar 11, 2007 - 6:53 PM) [snapback]535307[/snapback] QUOTE(x_itchy_b_x @ Mar 9, 2007 - 8:32 AM) [snapback]534627[/snapback] id jsut buy a cheap ebay one and take it apart to place the leds where ever. http://cgi.ebay.com/ebaymotors/RPM-SHIFT-L...093155726QQrdZ1 I didn't see any that cheap before. As long as it's acturate, it will work. What I would like is to make a device to tell me what gear the car is in, and that's pretty easy to set up. And also have a top limit and bottem limit. That way, while racing I could keep the car right wear it needs to be. it's fairly easy to do (i think) mount a plate with 3 micro switches on front and back of the shifter assembly, place them according to where the rod sits in each gear and have a "normaly closed" circuit for the neutral. Connect LEDs to a panel with semi transparent number/letters. You don't need a switch for reverse, you have the reverse light circuit. I thought about doing this and sticking the LEDs in the shifter itself (with a strong input resistor so they don't shine super bright) Micro switch:
This post has been edited by K-ESD: Mar 11, 2007 - 9:39 PM -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Mar 18, 2007 - 12:58 PM
Enthusiast ![]() ![]() Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) |
I remember a while back i saw this Mugen one where it was just i think a small LED bulb which was the shift light. I think that would be better. They mounted it on the steering column. I think that ebay shift like is too big. Anyone know or have any idea what im talkin about?
| Lo-Fi Version | Time is now: May 20th, 2026 - 3:38 PM |
