> Runnin wire
post Mar 9, 2007 - 5:05 PM
MeHoW
Joined Mar 9, '07
From Columbus
Hi!
Where I should drill a hole under the steerin wheel to have good access to run the wire to the battery from my amp. So far i went thru the door, but i would like to go thru the firewall smile.gif
Thank You for replies
post Mar 9, 2007 - 6:07 PM
azian_advanced
Joined Apr 18, '05
From Calgary
The "right way" to run a power wire for amps, A "how to" for the cleanest and reliable install
post Mar 9, 2007 - 6:17 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
I should of done mine the way K-ESD did mad.gif If you want to run a wire in the firewall, then you'll have to drill a hole in firewall first (I can't remember off the top of my head where I drilled the hole), top coat the visible bare metal with anti-rust or touch up paint, then add a rubber grommet so there will be a good seal when run the wire through the hole. At least that's how I did mine.
post Mar 9, 2007 - 9:51 PM
MeHoW
Joined Mar 9, '07
From Columbus
post Mar 9, 2007 - 10:52 PM
cnelson
Joined Dec 11, '06
From New Jersey
i thought there was a gromit where you could fit wires in the firewall? right by the glove box some where?
"Drive Well...
...Drift Better"
post Mar 10, 2007 - 12:33 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(cnelson @ Mar 9, 2007 - 9:52 PM) [snapback]534888[/snapback]
true, except the battery is located on the other side, so it's easier to do it from that one side.
Lo-Fi Version Time is now: August 4th, 2026 - 3:05 PM
