Mar 13, 2007 - 4:27 PM
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
Hello,
It is starting to get warm and she is finally almost finished. I have a st205 engine and a mr2 lsd trans. new clutch and pressure plate. I am currently using a gt slave cylinder, bacause it fit best due to the clocked turbo. However, there dosen't seem to be much pedal. It shifts into all of the gears smoothly and doesn't grind, but the pedal doesn't seem to have much movement. Just wanted to know which ones you all were using or if there was a different pin in between the slave and fork thing. Thanks Lance |
lantz2121 Slave cylinder question for swapers. Mar 13, 2007 - 4:27 PM
Punisher The little pushrod or whatever you wish to call it... Mar 13, 2007 - 4:34 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:51 AM |
