> Antenna and speakers
post Jul 16, 2003 - 5:45 PM
Gerry
Joined Apr 3, '03
From Ireland
Hi there
My antenna starting making noise and it would not go down unless you pushed it down, so I unplugged all the connections to the motor on it and got the antenna lead connecting in to the outside antenna and connected it to the body of the car and the radio works fine now and I don't have that huge arial up now BUT went for a drive in the car after doing the job and I noticed that the speaker on the drivers side didn't work(it may not have worked before I went at this I'm not sure) so I took out the radio thinkin it might be a loose connection, put the radio back in and now the back drivers speaker won't work either, the little tweeter will work though. I was just wondering if it would have anything to do with the antenna or what I did with it..Maybe I should have left it to the experts...solve one problem and make myself a bigger..I didn't take out the radio again to see if it is a loose lead, will try it again tomorrow...Any help on this would be great ..Thanks!!
Replies (1 - 3)
post Jul 16, 2003 - 10:03 PM
blkGT
Joined Jun 10, '03
From FL
Hey Sorry I cant help you. But could you/or someone explain what wires to rip out for the antenna. I have an s2000 antenna and that motor just wont die!
post Jul 17, 2003 - 9:11 AM
BlackSTX
Joined May 17, '03
From Florence, KY
I think you just have to unplug the wires in with that little white connector. The only ones I remember on my power antenna are that and the antenna cable. Unplug the white clip with all the little wires and leave the antenna wire connected. Hope that helps.
post Jul 17, 2003 - 5:35 PM
Gerry
Joined Apr 3, '03
From Ireland
thanks .....I found out later that the speaker is gone...an now I battery run down and I can't start the car because of the alarm is doing some funny ****....this day just gets worse and worse...lol....I should leave things alone in future rolleyes.gif
Lo-Fi Version Time is now: March 25th, 2026 - 10:30 AM
