Mar 18, 2007 - 8:07 PM
they 6.5"? or 6x9"? also if there 6.5"...can you upgrade to 6x9"??
Mar 19, 2007 - 6:16 AM
Enthusiast ![]() ![]() Joined Sep 28, '06 From Montreal, QC, Canada Currently Offline Reputation: 2 (100%) |
They're 6.5" and you have to grind some ridges on the stock brackets to get them to fit. Don't bother buying 6x9"s, just buy some good 6.5s. Besides, you'd probably need to make another bracket to fit them.
-------------------- One o'dem crazy Canadian freaks, eh?
Mar 19, 2007 - 4:45 PM
![]() Enthusiast ![]() Joined Feb 8, '07 From Oakland, Ca USA Currently Offline Reputation: 0 (0%) |
Agreed.... 6x9's arent worth the hassle of modifying the panels to make them fit.
-------------------- -M-
Mar 19, 2007 - 4:57 PM
![]() Enthusiast ![]() ![]() Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Depending on what 6.5" you get you may not even have to cut the stock mounts in the rear.
Mar 19, 2007 - 7:36 PM
QUOTE(GTS13 @ Mar 19, 2007 - 4:57 PM) [snapback]537764[/snapback] Depending on what 6.5" you get you may not even have to cut the stock mounts in the rear. I don't see how that's possible. Yes, the hole is the appropriate dimension, but there are some grooves that keep the speaker from sitting right. you will have to grind those down. -------------------- One o'dem crazy Canadian freaks, eh?
Mar 20, 2007 - 4:13 PM
If you get shallow mount speakers, or in my case I got Infinity Kappa speakers that are high quality low profile speakers you should be fine. I installed mine without any problems or having to do any grinding.
Mar 20, 2007 - 4:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
My R-F Fanatic Series Component 6.5"s fit just fine. You just can't use 1 screw and it doesn't cause any rattles or anything. Don't worry so much about this. It will work.
Mar 20, 2007 - 6:31 PM
Yeah I wouldn't worry I was able to use all my screws, guess it just depends on the speakers you buy, but it's nothing serious.
| Lo-Fi Version | Time is now: August 4th, 2026 - 5:13 PM |
