Mar 21, 2007 - 4:04 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
Ok so who went with tanabe coilovers instead of tein coilovers? and how do you like them? did you get the ones with the helper spring or not and what was the reason? Is there any reason y i wouldnt get the one with the helper spring? I know tanabes are not adjustable like teins but the tanabes have a stiffer sprig rate then the teins. Plus for me adjusting might be a pain in the butt as ill always want to play with it.
The reason why i ask is because after reading all the coilover threads most of the ppl on the board seem to have gone with teins and i havnt read one speck on anyones views with the tanabe coilovers. Other then tein and tanabe are there any other companies that make a full coilover and strut set up that wouldnt be a custom job? Ive recently seen D2 making coilovers for our cars but how r those? as a side note i also plan on using ST swaybars front and rear. from what ive seen this whats out there tein spring rate 7.0/5.0 adjustable monotube??? tanabe spring rate 8.0/6.0 non adjustable daul chamber (not so good for wear right???) helper spring D2 spring rate 7.5/5.1 adjustable monotube (good idea for wear right???) i figured that with the tanabe's ill lose adjustablity, which i dont mind as its one less thing to mess around with, however ill gain a stiffer spring rate and the helper spring should help with comfort a bit. thanks a bunch guys and gals. This post has been edited by urbandork: Apr 4, 2007 - 11:10 PM |
urbandork helper spirng or no helper spring????? Mar 21, 2007 - 4:04 AM
urbandork n e one? Mar 23, 2007 - 2:19 AM
urbandork still no replies. wow.
thinking about going with ... Mar 29, 2007 - 1:28 AM
Tigawoods same here, i prefer them over tein just b/c they h... Mar 30, 2007 - 12:40 PM
urbandork ive searched high and low for jic's and while ... Mar 31, 2007 - 2:36 AM
hellsyphon From what I've heard, Ksport and D2 coilovers ... Mar 31, 2007 - 2:56 AM
urbandork QUOTE(hellsyphon @ Mar 31, 2007 - 7... Mar 31, 2007 - 2:01 PM
Tigawoods i really think ksport would be the best bet, im ju... Mar 31, 2007 - 3:31 PM
airfron Craig i think you should go with the teins... the ... Apr 1, 2007 - 4:03 PM
urbandork QUOTE(airfron @ Apr 1, 2007 - 9:03 P... Apr 1, 2007 - 4:53 PM
airfron i just think that since the celi is your daily dri... Apr 1, 2007 - 5:04 PM
urbandork QUOTE(airfron @ Apr 1, 2007 - 10:04 ... Apr 1, 2007 - 6:02 PM
Tigawoods no ksport anymore?
the tanabe's are a little m... Apr 1, 2007 - 7:53 PM
Tigawoods oh wait now i just took a look at the d2 coilovers... Apr 2, 2007 - 9:11 AM
TJ97ST I don't know if this factors into your conside... Apr 2, 2007 - 3:45 PM
urbandork im probably going with tanabe's as they have t... Apr 4, 2007 - 11:16 PM
Tigawoods well the purpose of the helper springs is to fill ... Apr 6, 2007 - 8:56 AM
playr158 koni yellows + ground control coilovers (u specify... Apr 6, 2007 - 9:00 AM
Tigawoods ^+upper pillowball mount
too much work, just g... Apr 6, 2007 - 9:14 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 1:05 PM |
