> question about o2 sensors, CA spec has two, I want one
post Mar 22, 2007 - 10:20 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I have a CA spec car... this means, my car has 2 o2 sensors instead of one. when I go turbo (hopefully very soon) I'm sure the downpipe will only have a slot for one o2 sensor... so, is there like a resistor or something I can do so that my car doesn't freak out from only having one o2 sensor?
- 6strngs   question about o2 sensors   Mar 22, 2007 - 10:20 PM
- - Batman722   just get a dp with a second bung (for a wideband)....   Mar 22, 2007 - 10:25 PM
|- - 6strngs   QUOTE(Batman722 @ Mar 22, 2007 - 8:2...   Mar 22, 2007 - 10:28 PM
- - playr158   you can always have a 3rd bung installed....but is...   Mar 23, 2007 - 12:28 AM
|- - 6strngs   QUOTE(playr158 @ Mar 22, 2007 - 10:2...   Mar 23, 2007 - 12:41 AM
- - presure2   heres what you do. most (99%) of widebands also ou...   Mar 23, 2007 - 3:48 AM
|- - 6strngs   QUOTE(presure2 @ Mar 23, 2007 - 1:48...   Mar 23, 2007 - 1:51 PM
|- - presure2   QUOTE(6strngs @ Mar 23, 2007 - 1:51 ...   Mar 25, 2007 - 6:04 PM
|- - 6strngs   QUOTE(presure2 @ Mar 25, 2007 - 4:04...   Mar 25, 2007 - 11:15 PM
- - Negative   Except STs. o0black0o's 25th anny ST has the s...   Mar 23, 2007 - 10:13 AM
- - presure2   all the V1 and V2 pipes have the lower O2 bung, as...   Mar 27, 2007 - 4:22 PM
|- - 6strngs   QUOTE(presure2 @ Mar 27, 2007 - 2:22...   Mar 27, 2007 - 10:49 PM
- - Negative   I have 3 stock Turbo downpipes. I will check to se...   Mar 28, 2007 - 11:18 AM
|- - 6strngs   QUOTE(Negative @ Mar 28, 2007 - 9:18...   Mar 28, 2007 - 3:36 PM
- - Negative   Good plan but the second half of the 5s downpipe i...   Mar 28, 2007 - 3:49 PM
|- - 6strngs   QUOTE(Negative @ Mar 28, 2007 - 1:49...   Mar 28, 2007 - 9:08 PM
- - Negative   Got the downpipe and FMIC [Approx 30" x 10...   Mar 29, 2007 - 8:45 AM
|- - 6strngs   QUOTE(Negative @ Mar 29, 2007 - 6:45...   Mar 29, 2007 - 1:31 PM
|- - Negative   QUOTE(6strngs @ Mar 29, 2007 - 6:31 ...   Mar 29, 2007 - 4:13 PM
|- - presure2   QUOTE(Negative @ Mar 29, 2007 - 5:13...   Mar 29, 2007 - 4:36 PM
|- - 6strngs   QUOTE(presure2 @ Mar 29, 2007 - 2:36...   Mar 29, 2007 - 6:39 PM
- - Negative   OK well that saves me some time. I can still weld ...   Mar 29, 2007 - 4:51 PM
- - alltracman78   I have a question, out of curiosity. I'm not ...   Apr 4, 2007 - 5:25 PM
|- - presure2   QUOTE(alltracman78 @ Apr 4, 2007 - 6...   Apr 5, 2007 - 3:54 PM
- - 6strngs   yes, after closer inspection, the 2nd o2 sensor IS...   Apr 4, 2007 - 8:25 PM
|- - alltracman78   She has a different engine. I don't believe it...   Apr 5, 2007 - 10:25 AM
|- - 6strngs   QUOTE(alltracman78 @ Apr 5, 2007 - 8...   Apr 5, 2007 - 3:21 PM
|- - alltracman78   QUOTE(6strngs @ Apr 5, 2007 - 3:21 P...   Apr 5, 2007 - 6:54 PM
- - hurley97   this is of my 97 ST but it sounds like they are in...   Apr 4, 2007 - 11:07 PM
- - 6strngs   that's definately not where they are on a cali...   Apr 4, 2007 - 11:17 PM
- - 6strngs   yes, for the time being I want to use the stock CT...   Apr 6, 2007 - 12:08 AM
- - alltracman78   Personally, I would recommend a 3". Especiall...   Apr 6, 2007 - 12:35 PM
- - presure2   just FYI, ive had my 2nd O2 sensor installed in th...   Apr 7, 2007 - 8:03 AM
- - alltracman78   I stand corrected. Apparently the 94/95 O2 sensors...   Apr 8, 2007 - 1:13 PM
Lo-Fi Version Time is now: March 24th, 2026 - 1:01 PM
