Jul 17, 2003 - 7:30 AM
Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Can anyone help me and provide me with an explanantion.
I removed my passenger seat and dismantled it so that the seats could be re-covered, problem is, I'm having problems re-installing the back of the seat. There are four screws (2 each side) that fix to a plate either side. This is straight forward. However, it is the bar that runs through the base of the seat which has a tab at either end. It appears to locate into grooves but my problem is that the seat mechanism does not work. Do these tabs locate in a certain manner? Does the spring mechanism need to be put in a certain position before locating the tabs? Any help would be greatly appreciated. EDIT: I solved the problem and fixed everything last night. So, if anyone else runs into the same problem just contact me. This post has been edited by vphmc: Jul 18, 2003 - 4:00 AM |
| Lo-Fi Version | Time is now: September 16th, 2026 - 11:27 PM |
