Mar 24, 2007 - 4:40 AM
Enthusiast ![]() Joined May 20, '05 From San Diego, California Currently Offline Reputation: 0 (0%) |
I know I know, I used the search function but I couldn't find the answer.
Last night my car wouldn't start; I heard a click when I turned the key, but nothing happened. My friend jumpstarted my car and I managed to drive home. When I came home the car wouldn't start again by itself, so I replaced the battery. I still hear the clicking noise and the car still won't start. If I was able to jumpstart the car, is the problem with the battery and not the starter? This post has been edited by eyohannie: Mar 24, 2007 - 4:41 AM -------------------- |
Mar 24, 2007 - 4:48 AM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
i had the same problem for awhile, it turns out the negative terminal or postive one, i dont remember, was really loose. i dont know if thats your problem, but pur some coke on your battery and get all the crap off and tighten back down your terminals, see if that works man
-------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Mar 24, 2007 - 11:56 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Could be a dying/dead alternator. Sounds like what happened to me
Mar 24, 2007 - 11:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
clicking when turning the key is most likely your starter. I had the same problem when I bought my car. It died for good in a mall parking lot and I had to push it out of the parking spot and have my girlfriend dump it in 2nd or 3rd just to get it going.
Mar 24, 2007 - 12:12 PM
Enthusiast ![]() Joined Mar 16, '07 From the gap that lies between one microsecond and the next... Currently Offline Reputation: 0 (0%) |
pleck
This post has been edited by applejax: Mar 24, 2007 - 1:11 PM -------------------- The poster is not bound by any accuracy, stated or implied, of the previous post. Any similarities to actual people, fictional or real, may or may not be a coincidence.
--applejax |
Mar 24, 2007 - 1:09 PM
QUOTE A bad starter normally doesn't give you the "clickclickclickclick" when you try and start your car - that's usually a symptom of an electrical problem. I disagree. That is exactly what mine did and replacing the starter fixed the issue. maybe a constant clickclickclick, but when you turn your key and get one click and then nothing it is wise to look into the starter first. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
QUOTE(95CelicaST @ Mar 24, 2007 - 1:09 PM) [snapback]539389[/snapback] QUOTE A bad starter normally doesn't give you the "clickclickclickclick" when you try and start your car - that's usually a symptom of an electrical problem. I disagree. That is exactly what mine did and replacing the starter fixed the issue. maybe a constant clickclickclick, but when you turn your key and get one click and then nothing it is wise to look into the starter first. Yeah, that's what I thought. But I figure if I am able to jumpstart the car then the starter is not the problem? I'm just a little confused about what the connection between being able to jumpstart and if I have a bad starter. -------------------- |
QUOTE(95CelicaST @ Mar 24, 2007 - 2:09 PM) [snapback]539389[/snapback] QUOTE A bad starter normally doesn't give you the "clickclickclickclick" when you try and start your car - that's usually a symptom of an electrical problem. I disagree. That is exactly what mine did and replacing the starter fixed the issue. maybe a constant clickclickclick, but when you turn your key and get one click and then nothing it is wise to look into the starter first. Agreed - I actually edited my post to clarify, but it's not updated to reflect the changes. -------------------- The poster is not bound by any accuracy, stated or implied, of the previous post. Any similarities to actual people, fictional or real, may or may not be a coincidence.
--applejax |
Mar 24, 2007 - 2:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
sounds like a ground issue
Mar 24, 2007 - 3:40 PM
Well, I went to Pepboys and bought a starter ($150/ $30 refund if I bring in my old starter). Car works again but I didn't know starters were so freakin expensive. Autozone has ours for $160 and Kragen/Checkers has it for $140 (they were out of stock). For some reason they don't make generic (cheaper) starters for our cars?
Mar 25, 2007 - 1:28 AM
I got mine for 99 installed. Guess I got a good deal. I'm glad to hear it is back on the road. No more starter issues for a very long time (hopefully)
Mar 25, 2007 - 12:04 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
glad u have your car fixed.....my car had teh same problem but it turned out to be the pos. terminal cable was loose.......but thats another issue....
Mar 25, 2007 - 5:10 PM
It surprised me how easy it was to remove the old starter and install the new one. I took me less than 30 minutes to do the whole thing.
| Lo-Fi Version | Time is now: August 25th, 2026 - 10:02 AM |
