Apr 2, 2007 - 7:46 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
Im about to do a tune up and Ive read some forum discussion about "ngk copper" plugs. Are these the best to use to help reduce chance of knock? If so where do you get them? Thanks
Apr 2, 2007 - 8:07 PM
nkg bkr7e .
Apr 2, 2007 - 8:08 PM
QUOTE(lagos @ Apr 2, 2007 - 9:07 PM) [snapback]542507[/snapback] nkg bkr7e . x2 I bought a 10 pack off ebay for 20 bucks. not bad. This post has been edited by x_itchy_b_x: Apr 2, 2007 - 8:09 PM -------------------- |
Apr 2, 2007 - 8:24 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
rockauto sells them too
i bought like 60 over the summer(6-cylinder, sik of having like 2/6) -------------------- ![]() |
Apr 2, 2007 - 8:46 PM
my local advance auto sells them
Apr 3, 2007 - 8:24 AM
QUOTE(lagos @ Apr 2, 2007 - 8:46 PM) [snapback]542526[/snapback] my local advance auto sells them Thanks guys! I appriciate it! |
Apr 3, 2007 - 9:16 AM
they are real cheap since they're copper, but they get replaced more often
i believe the rule of thumb on SF was every or ever other oil change. sine they're like $1-2 each, just od every oil change -------------------- ![]() |
Apr 3, 2007 - 10:01 AM
QUOTE(Consynx @ Apr 3, 2007 - 9:16 AM) [snapback]542648[/snapback] they are real cheap since they're copper, but they get replaced more often i believe the rule of thumb on SF was every or ever other oil change. sine they're like $1-2 each, just od every oil change Yea, I figured that. I was going to buy 20 at a time and see what they look like after 3,000. |
Apr 3, 2007 - 3:51 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(lagos @ Apr 2, 2007 - 6:07 PM) [snapback]542507[/snapback] nkg bkr7e . -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Apr 4, 2007 - 5:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
I like the BKR7IEX [iridiums]
Coppers are real good, but they tend to foul out on the 3SGTE. Especially since we tend to run a step colder plug. But if you're going copper, BKR7ES, not E [V power instead of regular] IMO. -------------------- ![]() |
Apr 7, 2007 - 5:33 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
Two's R Us has them for $12.- Bkr7e
Apr 9, 2007 - 7:21 AM
Enthusiast ![]() ![]() Joined Nov 22, '05 From New Zealand, Hamilton Currently Offline Reputation: 2 (100%) |
What do you guys think of the hks and greedy spark plugs?
you can get them one step colder and they say they last for a long time? (and not to do with best value for money) |
Apr 9, 2007 - 8:56 AM
my clip came w/ HKS, they died right as i got the clip though.
i'll say that it has the thinnest "thing"(can't think of word) ever. . . so it's grounding distance had to be amazingly precise...sik, but expensive. coppers are cheap and although they die fast, lotsa supra guys love em...so :\ -------------------- ![]() |
Apr 12, 2007 - 6:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
how long would iridiums last compared to coppers?
Apr 13, 2007 - 1:17 AM
Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
In my opinion Iridium plugs are not worth it at all..I have only ever had problems running iridium plugs in the 3sgte engines...much better to go for the cheaper platinum plugs or normal copper core plugs which have never let me down yet. NGK are a good make along with Champion and Bosch...avoid Denso plugs if you can...the quality of build is not very good.
Apr 15, 2007 - 8:23 AM
![]() Enthusiast ![]() ![]() Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
I'm trying the TRD Iridium plugs at the moment - aka Denso IK22. The problem I had with NGK plugs (at least in Australia) is that the NGK BKR7EIX only comes in 1.1mm gapping, and not 0.8mm.
-------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Apr 18, 2007 - 12:04 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
ANY BOSCH Series avoid like the PLAGUE.
Apr 18, 2007 - 5:28 AM
QUOTE(soulshadow @ Apr 18, 2007 - 12:04 AM) [snapback]547998[/snapback] ANY BOSCH Series avoid like the PLAGUE. IMO thats a rule of thumb with ANY car! |
Apr 18, 2007 - 11:16 AM
QUOTE(soulshadow @ Apr 18, 2007 - 6:04 AM) [snapback]547998[/snapback] ANY BOSCH Series avoid like the PLAGUE. Why? I found bosch plugs to be very good in my car. |
Apr 18, 2007 - 1:16 PM
QUOTE(Insanity-74 @ Apr 18, 2007 - 11:16 AM) [snapback]548120[/snapback] QUOTE(soulshadow @ Apr 18, 2007 - 6:04 AM) [snapback]547998[/snapback] ANY BOSCH Series avoid like the PLAGUE. Why? I found bosch plugs to be very good in my car. Ive seen too many toyotas towed in because of bosch plugs. |
| Lo-Fi Version | Time is now: June 14th, 2026 - 10:21 AM |
