> ct 26, whats the stock psi for a ct26
post Apr 4, 2007 - 9:49 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
hey guys...i was just wondering what the stock psi is set at for a ct26...ive heard its at 7, but then ive also read somewhere that its in the 5psi range. does anyone know for sure?
- jcaron9gt4   ct 26   Apr 4, 2007 - 9:49 AM
- - shin   the stock wastegate is set at 7   Apr 4, 2007 - 10:18 AM
|- - jcaron9gt4   thanks alot   Apr 4, 2007 - 12:04 PM
- - alltracman78   On the Celica/MR2 it's ~ 8PSI [sometimes a bit...   Apr 4, 2007 - 5:10 PM
- - Supersprynt   Also depends on your sea level. Mine was 8-8.5.   Apr 4, 2007 - 8:08 PM
- - 6strngs   so, does this mean that if you put a CT-26 on a 5s...   Apr 4, 2007 - 9:13 PM
- - Supersprynt   No. Other variables control boost also, like exhau...   Apr 4, 2007 - 9:23 PM
- - bufferdan   Depends... my stock 93 mr2 ran 12psi stock....pu...   Apr 5, 2007 - 12:06 PM
- - lagos   QUOTE(bufferdan @ Apr 5, 2007 - 1:06...   Apr 5, 2007 - 12:13 PM
- - 6strngs   so, if I use a boost controller will I be able to ...   Apr 5, 2007 - 3:39 PM
|- - Cisco93lude   QUOTE(6strngs @ Apr 5, 2007 - 3:39 P...   Apr 5, 2007 - 6:16 PM
|- - toyotacrazy   QUOTE(6strngs @ Apr 5, 2007 - 3:39 P...   Apr 5, 2007 - 7:44 PM
|- - presure2   QUOTE(toyotacrazy @ Apr 5, 2007 - 8...   Apr 5, 2007 - 7:49 PM
- - alltracman78   Exactly And the TVSV can only raise boost from wh...   Apr 5, 2007 - 7:57 PM
|- - toyotacrazy   QUOTE(alltracman78 @ Apr 5, 2007 - 7...   Apr 5, 2007 - 8:53 PM
|- - alltracman78   QUOTE(toyotacrazy @ Apr 5, 2007 - 8...   Apr 6, 2007 - 12:27 PM
|- - toyotacrazy   QUOTE(alltracman78 @ Apr 6, 2007 - 12...   Apr 6, 2007 - 4:51 PM
|- - presure2   QUOTE(toyotacrazy @ Apr 6, 2007 - 5...   Apr 6, 2007 - 6:11 PM
|- - toyotacrazy   sorry posted to wrong topic   Apr 6, 2007 - 6:24 PM
|- - Gary   QUOTE(presure2 @ Apr 6, 2007 - 6:11 ...   Apr 6, 2007 - 7:02 PM
- - 6strngs   ok. I think I understand now. and I think I can sc...   Apr 5, 2007 - 11:55 PM
- - x_itchy_b_x   QUOTE(toyotacrazy @ Apr 6, 2007 - 5...   Apr 6, 2007 - 5:36 PM
|- - alltracman78   For a while I was swapping the damn things in my s...   Apr 6, 2007 - 7:36 PM
- - toyotacrazy   My wastegate must not be operating correctly. B/C...   Apr 6, 2007 - 11:11 PM
- - presure2   are you swapped with a stock exhaust? if not, you ...   Apr 7, 2007 - 5:31 AM
|- - malecrod   QUOTE(presure2 @ Apr 7, 2007 - 5:31 ...   Apr 8, 2007 - 3:09 PM
- - alltracman78   Don't forget, massively retarded timing, such ...   Apr 8, 2007 - 4:15 PM
|- - toyotacrazy   QUOTE(alltracman78 @ Apr 8, 2007 - 4...   Apr 8, 2007 - 4:30 PM
- - 95celgt   hmmmm, so much inconsistency, I just got a MBC bec...   Apr 20, 2007 - 1:37 PM
|- - Gary   QUOTE(95celgt @ Apr 20, 2007 - 1:37 ...   Apr 20, 2007 - 1:59 PM
- - Alan   Mine is 10psi stock not boosted, this is because o...   Apr 22, 2007 - 11:01 AM
Lo-Fi Version Time is now: June 23rd, 2026 - 8:13 AM
