Apr 5, 2007 - 1:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
Im trying to find some dash trim but cant find any.Is there any that fits perfectly.I was looking through the parts database and they had some but idk what it looks like inside the car,and they said it doesnt fit perfectly.Pictures would be nice!!!thank you
-------------------- BANNED. for life, you moron.
Apr 5, 2007 - 2:02 PM
Enthusiast ![]() ![]() Joined Mar 22, '07 From Greenville NC Currently Offline Reputation: 0 (0%) |
you can always just paint it, whatever color just get that paint, even if you want chrome just make sure you do a good clearcoat on it
Apr 5, 2007 - 2:03 PM
Enthusiast ![]() ![]() ![]() Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
id go with paint...i bought some vinyl and tryed to heat wrap it, but it didnt turn out that great. if i had to do it again i would deffinitely paint it.
Apr 5, 2007 - 2:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
wrap it in carbon fiber.
Apr 5, 2007 - 4:13 PM
![]() Enthusiast ![]() Joined Feb 8, '07 From Oakland, Ca USA Currently Offline Reputation: 0 (0%) |
I used Krylon Fusion paint.... looked factory when it was all done and it was only like 6 bucks for the can.
-------------------- -M-
Apr 5, 2007 - 4:39 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
i want to paint mine a silver in the future but can't figure out (for the life of me) how do you get the passenger side vent out? the others seem to pop out fairly easily but not that one. i read somewhere that it really easy to snap some type of clip when doing it and i want to avoid that if possible. maybe someone should put this in the how to's
Apr 5, 2007 - 4:45 PM
That one is a hard one, and a lot of people have broken a tab that holds it in place.... I tried it, but was affraid of breaking it, so I stopped....
Patience and minimal force are 2 things I have a problem with... -------------------- -M-
Apr 5, 2007 - 5:21 PM
fi the tab breaks, it will go back in, i broke mine off and its back in place and holding just fine, i wouldnt worry about it too much if i was you.
Apr 6, 2007 - 2:30 PM
What kind of paint should buy and where?Im near a autozone,kragen,Big O(lol),and much more.Also can i just tape everything up then paint it or do i have to take it all out to paint it?
Apr 6, 2007 - 2:33 PM
i used krylon for plastics from walmart and mine turned out pretty nice, and i wouldnt recommend painting in the car, the fumes will linger for a long time and you will get over spray on everything, plus its best to have it laying flat so you dont see runs on the front of it, its not too hard to take out except for the passenger vent, but it doesnt take too long to get them out and the paint and clear coat will dry in about an hour so it wont take too long either. make sure when your done you post pics so we can see it
Apr 6, 2007 - 2:37 PM
Ok thx ill go to walmart today or tomorow and look at that stuff and mabye even do it today.Today i realized i hate my interior
Apr 6, 2007 - 2:40 PM
Its called Krylon Fusion.... and it works real well...
Apr 6, 2007 - 3:34 PM
QUOTE(mikeismad0408 @ Apr 5, 2007 - 4:21 PM) [snapback]543631[/snapback] fi the tab breaks, it will go back in, i broke mine off and its back in place and holding just fine, i wouldnt worry about it too much if i was you. ok so what tactics should i use to get it out? just pull like a mo fo til it just pops out perhaps breaking the tab and everything? or is there a better way? also after spraying even with the krylon fusion stuff should i still clear coat it? and about how many coats of paint should i do? just what it says on the can? This post has been edited by goferris: Apr 6, 2007 - 3:46 PM -------------------- |
i believe the tabs were on the bottom so just pull/pry from the top...slowly...and just work it out. if you break off a tab its no biggy the vent will still go back in place just fine.
This post has been edited by DSToyo: Apr 6, 2007 - 3:47 PM |
yeah, the best thing to do is to get something and pry it out, i used a flat head screw driver and once i had it started i just pryed it the rest of the way out, and i would do 2 or 3 thin layers of paint and then 3 or 4 good layers of clear coat so you know its not coming off.
Apr 6, 2007 - 8:21 PM
to get the passenger vent out, you must be really carefull. Once you take the glove compartment, you can have acess from below. These litte tabs look like a "U", but they are flexible, with a small scredriver, you can ben them, and once "_____" shape not "U" shape, you can take it out. I recently had to fiddle with it, cause i hand washed all my trim, too much dust and also i had the original wooded grain that was all craked up. I put my pieces in the sun to soften the grain, took it oof and used goo gone to remove the glue. Just trying to help....
| Lo-Fi Version | Time is now: July 11th, 2026 - 11:41 AM |
