Apr 6, 2007 - 3:33 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
ok..so i got a window rollup module, but after everything is wired i get three clicks coming from the module everytime it receives a signal...and the windows wont roll up. wtf??
i connect: the red wire to the + ter the yell wire to the ignition ON blacky to - ter ...powerout from the module i connect them to the green & red wires of the motor.. ....signal wire is connected to the actuator.... ...and...click...click...click.... can anyone please shine a light for me on this..i have been looking at it for the past 3 hours but...*sigh* thanks -------------------- ![]() 98% completion --- aaRon |
Apr 6, 2007 - 6:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
what are you using to activate the module?
you need a constant negative ground for the window module to work. (this may very depending on each manufacture. but the general installation requires this) |
Apr 7, 2007 - 1:30 AM
im using a negative wire of the actuator of the driver's door.which might not be correct..(blue/white)
can you tell me all the wire colours that i have to connect the module to in order for it to work, thanks edit: i found a link http://www.caraudiomag.com/technical/0508c..._window_module/ it says that i need to slice one of the motor wire and connect the two wires from the module to it...but thats a roll up/dn module (fig2). mine is only up..so i don think i need to cut anything do i? This post has been edited by lubu: Apr 8, 2007 - 1:01 AM -------------------- ![]() 98% completion --- aaRon |
Apr 8, 2007 - 1:02 AM
...here is a diagram for my setup http://home.exetel.com.au/lubu/module..
Apr 8, 2007 - 2:48 AM
i'm slightly confused..
can you show me the wire diagram on the window roll up module. for my set up i had to cut the motor wire also. here are the wire colors for the windows on the celica: LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down Grn/Wht - Red/Wht LR window switch RR Window up/down Green - Red RR window switch |
Apr 8, 2007 - 3:14 AM
ok....so which wires i have to cut and join with those coming from the module?
yea the diagram i showed you is similar if not exactly same as the module's manual. those wires are coming out from the module. LF n RF i understand but LR n RR, r those stands for left and right rear?? celica only has two door isnt it? ...confused... This post has been edited by lubu: Apr 8, 2007 - 4:03 AM -------------------- ![]() 98% completion --- aaRon |
Apr 8, 2007 - 7:50 AM
The celica convertable have rear windows. Since you didn't state what kind of celica you own, i decided to post all four windows just incase.
well, if this is the standard window roll up module. Then you will need to cut the green and green/white wires at your window switch and attach it to your module. just like figure 2 of your diagram. I dont understand why you would need a relay. another thing to note is, you do not need to attach the green/yellow wire to your acc. try that and let me know if it works. This post has been edited by Hanyo: Apr 8, 2007 - 7:50 AM |
Apr 8, 2007 - 10:35 AM
ok, i'll try that tomorrow..just bak from movie... 300..its awesome.
just to make sure, abt the signal which wire should i connect it to? ....thanks ED: i opened the module today, changed the configuration abit. Originally it has 5 doors as factory settings, so i turned the other 3 jumpers off. now it gives me 1 click then a long pause then another click......think the pauses are meant for rolling up the windows. oh well..let u know tomorrow This post has been edited by lubu: Apr 8, 2007 - 11:25 AM -------------------- ![]() 98% completion --- aaRon |
Apr 8, 2007 - 5:55 PM
it depends on what module it is.
i think your module rolls up one window at a time. So the first click is the first window, and the second click is the second window to be rolled up. |
| Lo-Fi Version | Time is now: September 4th, 2026 - 5:42 AM |
