post Apr 8, 2007 - 9:09 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
what do you guys do to keep your couplers from poping off your intercooler piping? i just tryed sealing it with high temp silicone then clamping it down but i only did it in one spot to see if it would work. so far so good
BOOST GETS YOU LAID!!!!
post Apr 8, 2007 - 10:46 PM
99GT
Joined Dec 14, '06
From MN, USA
T-Bolts!!!!
post Apr 8, 2007 - 11:10 PM
tbolts. in almost 3yrs i have not had a single pipe come loose with them installed.
post Apr 8, 2007 - 11:14 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
^^^ Tbolts are indeed the way to go.
post Apr 9, 2007 - 2:10 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
X2 its a necessity...
post Apr 9, 2007 - 4:43 AM
Gary
Joined Aug 28, '04
From FLA USA
T-bolt clamps will hold them for sure in most cases.
For higher boost application, use t-bolt clamps and get some bead weld on the ends of the piping or flare them.
This post has been edited by Gary: Apr 9, 2007 - 4:44 AM
_Gary
post Apr 9, 2007 - 11:05 PM
southwest2118
Joined Jan 13, '06
put some deep scratches on the ends of the pipe.... spray brake cleaner on then before putting'em on......works for me.......but i'm only pushing 10psi
Lo-Fi Version Time is now: September 11th, 2026 - 11:07 AM
