Apr 12, 2007 - 1:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
So on my 3s, there are 2 ports that come out of the throttle body, are they both supposed to be under vac.?
The reason I ask is because my car has crappy vac now at idle, 15 when the fuel pump sounds like its pumping at a fast pace, then the fuel pump clicks into a slower pace and drops to 10vac. and it basically idles like crap and trembles and stutters... On mine only one side does anything, im using that port for my BOV and my Boost/Vac guage, the other one is connected to the charcoal canister, is that where its supposed to go? Since the port connected to the canister is dead, i want to know if the cansiter is supposed to be under vac. I tried putting that red hose that goes to the canister at the T in place of the BOV to see what it does, the idle stabilizes nicely but at a higher rpm, and the guage reads that it runs at "0" so at atmospheric pressure. I ask for a few words of wisdom, thanks |
Apr 12, 2007 - 2:06 PM
Apr 12, 2007 - 3:41 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
If you are talking about 2 small ports on the top of the TB, those you can just plug them.
The one that points to the front of the car is for EGR valve. I removed the EGR, so I plug it. The other one is for the charcoal canister, I also removed the canister, so I plug that too. -------------------- _Gary
Apr 13, 2007 - 7:16 AM
side note. neat idea in that pic with the TB intercooling pipe.
Apr 13, 2007 - 10:51 AM
the welded flange?
So should the canister be under vac? How come it idles nice but makes the engine run at atmosphere? |
Apr 13, 2007 - 4:56 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(95celgt @ Apr 13, 2007 - 8:51 AM) [snapback]546379[/snapback] the welded flange? So should the canister be under vac? How come it idles nice but makes the engine run at atmosphere? You should use the vacuum hose that goes to the stock BOV (if you have one) or any other line that comes directly off the intake manifold. I would also avoid using the line that goes to the MAP sensor, but with a gen2 motor (are you you using a gen2 or gen3 motor?) it is less critical. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Apr 13, 2007 - 8:12 PM
From the picture, that is 2nd gen engine.
Both ports are behind the TB. You also have another empty port behind the intake manifold. It is right down the second letter "T" in the word "toyoTa" I'm curious, what do you use the vacuum port on the right side of the manifold for? It's the port that you has a big vacuum hose with white letters connected to. You can T-off that one for the BOV and boost gauge too. -------------------- _Gary
| Lo-Fi Version | Time is now: September 11th, 2026 - 3:45 PM |
