> HKS Induction Kit Question
post Apr 21, 2007 - 8:17 AM
ravenabout
Joined Mar 29, '07
From Ireland
Hi,
I recently purchased a 1995 GT4. It has a HKS Induction kit fitted. Just have a query on it. Basically when I start the car, the engine sounds as normal. However when I press on the accelerator a noise comes into the Induction Kit. Its kind of hard to explain the exact noise, If I take my foot off the accelerator the noise will go out of the induction kit after around 20 seconds and the car sounds fine again. Then I touch the accelerator again the noise comes back into it. Is it some sort of fan or has anyone experienced this?
Thanks a million,
Kieran
Replies (1 - 18)
post Apr 21, 2007 - 8:44 AM
the sound of your turbo spooling up?
post Apr 21, 2007 - 10:15 AM
ravenabout
Joined Mar 29, '07
From Ireland
Its definitely not the turbo, the slightest touch of the accelerator and the noise comes into the induction kit..
post Apr 22, 2007 - 1:00 AM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(ravenabout @ Apr 21, 2007 - 8:15 AM) [snapback]549058[/snapback]
Ummmm.... it is very likely the intake. I have a '95 GT4 motor and that intake. Learn to love it...
If you are still worried, go to a local tuner shop and have them listen to the sound. I bet its normal.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 22, 2007 - 10:01 AM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
Does it sound like a whistling/whining?
post Apr 22, 2007 - 5:29 PM
ravenabout
Joined Mar 29, '07
From Ireland
QUOTE(celica3sgte @ Apr 22, 2007 - 4:01 PM) [snapback]549279[/snapback]
Yep its a whistling/whining noise alright. Is this normal or should I be worried? Its more annoying than anything as when the car is idling it takes around 20-30 seconds for the noise to go, then the car sounds fine again.... Then once i slightly touch the accelerator again the noise is back!
Thanks for the replies lads, I appreciate it.
post Apr 22, 2007 - 5:31 PM
haha that whistle is your turbo spooling......you know that process happens when you touch the gas lol,
it takes 20ish seconds because the turbine has to slow back down
This post has been edited by playr158: Apr 22, 2007 - 5:31 PM
post Apr 22, 2007 - 6:01 PM
neKronos
Joined Mar 28, '04
From Ann Arbor MI
I want a GT4 with HKS induction, i love the air suction shound.
post Apr 22, 2007 - 10:05 PM
zCelicaDude
Joined Nov 20, '06
From Auckland, New Zealand
biggrin.gif why would you not want to hear your jet plane take off.. respect tongue.gif
post Apr 22, 2007 - 10:10 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
20ish seconds for the turbine to slow down?
is that why Toyota went ceramic now? lol
post Apr 22, 2007 - 11:21 PM
we need that video of the dudes turbo that was still spinning like a min or two after they shut the car down.....laugh.gif
post Apr 23, 2007 - 3:18 AM
ravenabout
Joined Mar 29, '07
From Ireland
Cheers for the info. I just didnt think it was the turbo spooling up as I was just barely touching the accelerator and the noise was coming into it!
All the best,
Kieran
post Apr 23, 2007 - 12:39 PM
ok we lied to you...........its really your flux capacitor having a bad reaction with your muffler bearings....if you double check your halogen fluid that could be the cause of such bad reaction, if its low....
post Apr 23, 2007 - 4:47 PM
Consynx
Joined Dec 25, '02
honestly, no clue
i was going to say something pulley related that gets thrown off w/ a applied torque, then in time settles down. . .
i'm guessing since it's intake related that it's gotta be oil pressure related of some sort.
No clue how or what...just a complete guess if it makes the nosie for a long period after a tap of the gas.
post Apr 26, 2007 - 7:41 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(playr158 @ Apr 23, 2007 - 12:39 PM) [snapback]549641[/snapback]
Also check the conutenary valve, they tend to stick open causing the turbo to continue sucking air through the intake! laugh.gif
post Apr 26, 2007 - 7:55 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
any pics of the 4?
post Apr 27, 2007 - 9:52 AM
JWST205
Joined Apr 12, '07
From Netherlands
Get rid of it asap. The HKS induction kit is known to give problems. I've had one on mine when I bought my ST205, but it's a lousy kit. If you wan't to go for a good one, but the Apexi funnel or even the universal one. It costs 100 usd and is the best airfunnel you can get your hands on (it's actually REALLY tested by Apexi and produces quite reasonable spool-up gain on turbo's, that is when you use a CAI
post Apr 27, 2007 - 10:35 AM
Negative
Joined Apr 28, '04
From Houston, Texas
This thread makes me laugh and sad at the same time. Many people in the states would give their left nut to have that sound without spending tons of extra money to add a turbo. I wish I had your problem.
post Apr 29, 2007 - 8:05 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Negative @ Apr 27, 2007 - 10:35 AM) [snapback]551457[/snapback]
man, Id give both my nuts! biggrin.gif biggrin.gif Ive got 2 kids and dont need anymore! laugh.gif
Lo-Fi Version Time is now: August 31st, 2026 - 6:39 AM
