Apr 26, 2007 - 2:21 PM
Enthusiast Joined Apr 26, '07 From Fort Lauderdale, FL Currently Offline Reputation: 0 (0%) |
Hello everyone,
I have purchased 2 weeks ago a used 1995 St manual with 167,000 miles for $900.00 from my buddy, the condition of the car is great, except because friend of mine wasnt very cautious and carefull of his car, slacking on little problems causign others, anyways, my problem is this. At idling i hear knocking sound coming from the engine, listening closer i would think something sounds like there is a little problem. 1. Valve knocking 2. Piston slaping 3. Engine mount 4. Or i do not know a. Did some research, id there and engine knock than it needs to get adjusted, HOW? b. If there is a piston slap, check which one by disconnecting a spark plus wire from each cylinder at a time untill knocking stops to get the right one, if so, Than WHAT? c. Could it be an engine mount? Is so, than if i fill it with polytherine, from experience it will eliminate wheel hop but make higher vibrations, but will it mount better? sounds silly when someone may fill in broken engine mount to fix it, is it not? If it something else let me know, please, i am slowelly repairing and tuning it up, so let me know, cause i want it to work well, thanks. |
naxxal Noise coming from the engine Apr 26, 2007 - 2:21 PM
lagos you can rule out piston slap.
get a video of the... Apr 26, 2007 - 2:27 PM
naxxal QUOTE(lagos @ Apr 26, 2007 - 7:27 PM... Apr 26, 2007 - 2:49 PM
Kwanza26 QUOTE(naxxal @ Apr 26, 2007 - 7:49 P... Apr 26, 2007 - 2:58 PM
naxxal QUOTE(Kwanza26 @ Apr 26, 2007 - 7:58... Apr 26, 2007 - 3:25 PM
Kwanza26 QUOTE(naxxal @ Apr 26, 2007 - 8:25 P... Apr 26, 2007 - 3:49 PM
toyotacrazy QUOTE(naxxal @ Apr 26, 2007 - 2:21 P... Apr 26, 2007 - 7:44 PM
Tigawoods well i had a knocking sound when i reved and i had... Apr 26, 2007 - 9:39 PM
toyotacrazy QUOTE(Tigawoods @ Apr 26, 2007 - 9:3... Apr 26, 2007 - 10:14 PM
lagos normally if you have a noise in the bottom end, it... Apr 26, 2007 - 9:48 PM
naxxal QUOTE(lagos @ Apr 27, 2007 - 2:48 AM... Apr 27, 2007 - 12:11 AM
Redline08 It might be your lifters, LOTS of yotas develop li... Apr 27, 2007 - 12:29 PM
Tigawoods this is sounding way too familiar. if it is a rod ... Apr 27, 2007 - 8:06 PM
DrAg1n320 Hey, thought i'd be able to chime in a little ... May 3, 2007 - 9:53 PM
alltracman78 QUOTE(DrAg1n320 @ May 3, 2007 - 9:53... May 10, 2007 - 11:01 PM
rjbibeau does the oil light flicker...if so you spun a rod ... May 4, 2007 - 9:58 AM
topshed It's probably big end bearings worn,connect an... May 4, 2007 - 11:51 AM
Nemises When was the timing belt last changed? They will s... May 4, 2007 - 4:20 PM
naxxal Hey guys, man so many replies, thanks alot, well i... May 10, 2007 - 3:12 PM
Redline08 QUOTEThe cam lobes hitting the shims on top of the... May 11, 2007 - 9:09 PM
stephen_lee yeah, my valve train is also pretty noisy.. i... May 13, 2007 - 1:32 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 12:59 PM |
